Air in brake lines and scoring on pistons at annual
We are doing the second annual on our RV-7 and have noticed air in the brake lines and scoring on all four master cylinder pushrod/pistons. We have bled the system but every time the brakes are cycled they appear to be sucking air into the supply side. There is about 6 inches of air there. Because it is the supply side, the brakes still feel fine. The set-up is standard Vans.
Has anybody come across this before and are the air and the scoring related?
These Matco master cylinders appear to be designed to be used the opposite way up. There is no dust shield around the pistons.
Loman O'Byrne
RV9 TU. O-320-E2D. Engine hung, working on FWF, Arklow, Ireland
=VAF= dues paid through Dec 2020
