12-14-2012, 01:39 PM
Contego works by forming a puffy char layer as an insulator. The char is very soft and fragile. Given 1~3 lbs/sec engine compartment airflow and sheet metal vibration the char will be destroyed as fast as it forms, meaning no insulation value.
Good stuff if you want to add fire resistance to your shop wall......
Dan Horton
RV-8 SS
Barrett IO-390
12-14-2012, 02:45 PM
§ 23.1191 Firewalls.
(f) Compliance with the criteria for fireproof materials or components must be shown as follows:
(1) The flame to which the materials or components are subjected must be 2,000 ±150 °F.
(2) Sheet materials approximately 10 inches square must be subjected to the flame from a suitable burner.
(3) The flame must be large enough to maintain the required test temperature over an area approximately five inches square.
(g) Firewall materials and fittings must resist flame penetration for at least 15 minutes.
§ 23.1182 Nacelle areas behind firewalls.
Components, lines, and fittings, except those subject to the provisions of §23.1351(e), located behind the engine-compartment firewall must be constructed of such materials and located at such distances from the firewall that they will not suffer damage sufficient to endanger the airplane if a portion of the engine side of the firewall is subjected to a flame temperature of not less than 2000 °F for 15 minutes.
Dan Horton
RV-8 SS
Barrett IO-390
12-14-2012, 03:40 PM
Dan, step away from the computer and fabricate something cool with a stiff drink in your other hand  .
Scott Card
CMW E-Lift
12-14-2012, 08:23 PM
My head hurts!
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
12-14-2012, 11:06 PM
C'mon Dan, it can't be that bad. I'd ask you to simulate another test with a sheet of SS and a giant fan to simulate the airflow, but I'd get another funny picture of a bunny (?) beating his head against a wall.
There has to be some value in using it...even if it only buys you a minute or two. Of course, I'm just hoping...
Maybe I'll buy a quart and attempt to validate your hypothesis on my own. Also, I'm not sure that on the center of the firewall you would get that kind of air movement. Maybe at the very bottom...(where the fire is...I know, I know)...
Sonny W
Boise, Idaho
RV-7A Flying!
12-14-2012, 11:15 PM
Airbox stiffener
Originally Posted by Steve Melton
air box stiffener made from alum tube.
Is this airbox stiffener needed?
Hans Str?hle
Jodel sold (SE-XEV)
RV-4, flying any day (SE-XJJ)
F?rentuna, Stockholm
Sweden
EAA222
2020 =VAF= $20 donation paid
12-15-2012, 02:33 AM
No, please don't step away. I find your tests extremely valuable, and while it might be inconvenient to hear for some, it is important that you share your results. Thanks a lot for that!
Hendrik
Club-Libelle: flying
RV-8: on hold (new job  , new home  , no workshop (yet)  )
12-15-2012, 05:15 AM
I know Dan personally and you can take what he says to the bank.
It may not be what you wanna hear but isn't that really what this site is for?
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
12-15-2012, 07:39 AM
Only if you want to prevent cracks in the mounting plate
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
12-15-2012, 09:49 AM
Nice!!!!!!!!
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
