Old 12-12-2012, 10:34 AM
Bad Sheila's Avatar
Bad Sheila Bad Sheila is offline
Talking Spark Pluge & Wires (RV-6)
What are the best spark plugs and wires for an O320 (160 hp) with magnetos?
Old 01-04-2013, 11:43 PM
Larry D. Miller Larry D. Miller is offline
Default O-320 plugs
Not sure they're the best, but I've mostly used REM-40E's (Champion) and have been happy with them. I might try Tempest UREM-40E's next just to save some bucks.
Old 01-05-2013, 01:25 AM
SHIPCHIEF SHIPCHIEF is offline
I have Skytronic Aero-lite harnesses (plug wires) that are over 10 years old.
When I sent the mags & harness in to Aircraft Magneto Service for the 500 hour inspection/rebuild, the harness came back yet again, tested, inspected and returned to service.
I would call that satisfactory.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 01-05-2013, 01:34 AM
Silent_Flyer Silent_Flyer is offline
See Mike Busch's Webinar on Spark Plugs. You'll learn all about them, construction,maintenance, cleaning and checking. I think you will see why he recommends Tempest because of a ldocumented reliability record with long ,ean time between failure of the Tempest plugs.
http://www.eaavideo.org/video.aspx?v=1826468805001
Cheers
Silent Flyer
Flying:
RV-4 Partnership
ASW-20B Sailplane
Want to build: RV-8 Starting in 2013
VAF Annual Donation Happily Submitted
Old 01-05-2013, 01:49 AM
MauiLvrs's Avatar
MauiLvrs MauiLvrs is offline
Originally Posted by Silent_Flyer View Post
... he recommends Tempest because of a ldocumented reliability record with long ,ean time between failure of the Tempest plugs.
And significant;y improved design...
Dave & Trina
RV-9A Flying - 330 Hrs. Painted Finishing the interior.
