Old 12-11-2012, 08:12 PM
lllewis45 lllewis45 is offline
Default Inflight open canopy
Since it is recommended to unlatch your canopy before landing off-field, I was wondering what testing or experience there is out there as to the affect an open (partially or fully) canopy has on aircraft control. I own an RV-7A.
LLL
Old 12-11-2012, 08:40 PM
PCHunt PCHunt is online now
Default Tip Up Canopy
My RV-6A made a successful takeoff with the tip-up canopy unlatched. The canopy "flew" slightly up in the airstream, trailing edge was about 10" or so up, and floating easily, if noisily. The pilot (fortunately, not me) was able to clear the pattern, slow down at a safe altitude, and close and lock the canopy.
Alternatively, he could have come back and landed, and secured the canopy on the ground.
One data point for you. You might find many more if you do a search on this forum, as the issue has been discussed quite a bit.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 12-11-2012, 08:42 PM
kevinh's Avatar
kevinh kevinh is offline
For my slider, aerodynamic forces will hold it open about one inch. No issue otherwise...
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
