Old 12-11-2012, 06:47 AM
beberle beberle is offline
Default Rudder cable bulkhead hole
I'm having a problem with rudder travel. Right rudder is fine, the clevis just hits the snap bushing in the left bulkhead. After much research, I'll be adding the split tubing to smooth that out.
However, Left rudder travel seems to be limited either by rudder cable length or because the right bulkhead hole is too low. The clevis body doesn't move far enough aft to hit the snap bushing because of cable tension.
Any thoughts?
Old 12-11-2012, 09:47 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
Have you set your rudder stops yet? With the rudder stops set to recommended travel, this might be a non-issue. I know this is very close and I wondered about it when I built my 7A. Never had a problem once completed, though.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 12-11-2012, 11:43 AM
I just purchased my 6-A two months ago. The rudder will come close or hit the right stop, but the left won't because of the cable bend at the 1st bulkhead. I'll have to measure the rudder deflection left and right to see where I'm at.
______________
Brian Eberle
RV-6A
KFFC
Carpe Diem!
Old 12-11-2012, 02:21 PM
gasman gasman is offline
If your kit was purchased around mid April 1998, Van's shipped the wrong cables to a few customers. The correct cable number is F-6121.
Drawing #40 shows them to be 161" eye to eye.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 12-12-2012, 09:31 AM
AF_Alan's Avatar
AF_Alan AF_Alan is offline
Default Same problem
I recently connected the rudder cables on my 9A for the first time and found the same issue...good throw to the right but less than 1/2 deflection required on left pedal due to cable angle between pedal and co-pilot 1st bulkhead, exactly like your picture.
Appears my problem is that I positioned the pedals for comfort (tops leaning slightly forward) instead of vertical. My plan is to lengthen the rudder cable links (F-6119) about 1" to get the bottom edge of the pedals further forward from the 1st bulkhead. Haven't tried it yet. Downside is potential to ride the brakes on the ground or having to add an aftermarket extension on pedal bottoms.
Good luck!
Alan
RV-9A N984AW
Old 12-12-2012, 09:50 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
Alan,
Unfortunately, changing the length of the links will probably not address your issue, at least not fully. It's largely a function of how long the cables are. One thing that I found helped was to insert the bushing from aft side of the bulkhead. Though counterintuitive, it better guides the clevis toward the hole in the bulkhead. This topic has been addressed a number of times in the past, so if you search a bit in the archives you should find some more to mull over. Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 12-12-2012, 10:21 AM
jimbower jimbower is offline
My rudder cable clevises were knocking the snap bushings out too...then I inserted them from the front and all was well.
Jim Bower
St. Louis, MO
RV-6A N143DJ
Flying
Old 12-12-2012, 11:38 AM
az_gila's Avatar
az_gila az_gila is offline
This is a -6x correct?
There was a change in hole location on the vertical web (F-602) nearest the rudder pedals when Van changed from the floor mounted pedals to the overhead hanging ones.
The hole was changed to be 7 inches above top surface of the lower longeron.
Rev R6 on sheet 25
Do you have the lower old hole locations?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-12-2012, 12:47 PM
WenEng WenEng is offline
Default Your pedals may be sitting aft a little far
What makes me think so is the higher angle from the Clevis to the snap bushing and the shortness of the link. Az_gila has a point to check out first. Setting pedals is such a personal thing. The previous owner may have had short legs, or wanted the pedal bottoms canted rearwards more for the neutral position. The further forward the rudder pedal bars are located and drilled through the longerons and the further towards vertical the pedals hang, the lower that angle is. For peace of mind, why don't you clamp the rudder in neutral and disconnect the two links and see what it looks like with the rudder pedals in a nearly vertical resting position (maybe canted aft just a little). You may end up making new links, each side being a different length.
See this link for just one example.....
http://www.rivetbangers.com/forums/v...asc&highlight=
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
Old 12-13-2012, 06:57 AM
airtractor8 airtractor8 is offline
Any thoughts?
I had exactly the same problem with my 93' RV6. The rudder cables clevis would hit the snap bushing before reaching full travel. It was the same on both sides. The cable also did not have a straight pull just like your pic but probably not as bad.
To fix this I elongated the hole in the bulkhead so I got a straight pull for the cable and then made a "U" shaped stand off from .032 and riveted this to the rear side of the bulkhead. It had the hole in it for the snap bushing. Doing this placed the snap bushing further rearward and so I got both a straight pull for the cables and no fouling of the clevis end to the snap bushing.
I originally thought about adding the split tubing as you suggest but that did not solve the cable being deflected as shown in your pic. I am sure if left like that it will wear through the snap bushing and you will have cable wearing on bulkhead in no time.
A written description is always harder to understand than a picture so I will take some for you and post here tomorrow. It was an easy fix.
