Old 12-11-2012, 07:16 AM
Roberto RV-7's Avatar
Roberto RV-7 Roberto RV-7 is offline
Default Argentinean Rol! ;)
Roberto
RV-7 builder and pilot
Old 12-11-2012, 07:36 AM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
Sorry Roberto,
It seems that the link is broken.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
Old 12-11-2012, 08:06 AM
Bastien's Avatar
Bastien Bastien is offline
link now work properly
Very nice shot !!
Is it the smoking airplane smoke system or an homemade one ?
edit: it is quite interesting to see the smoke between the two exhaust pipes.
Van's RV-8 3040 F-PVRB
Aerosport IO-375 turning WW200RV
Dual Dynon SV1000
SJ Wheel pants/plenum/cowl
Flying since 07/27/12
Van's RV-8 2513 F-PTGV
Lycoming IO-360 B1B
Purchased as a project--Finishing kit
Old 12-11-2012, 10:07 AM
Low Pass's Avatar
Low Pass Low Pass is offline
Very nice shot !!
Beat me to the question. Second - what is that smoke system, and what fluid are you using??
Excellent photo, btw!!
Old 12-11-2012, 11:26 AM
It's a homemade smoke
Built with elements aeronautical, copy of fuel tanks, AN fittings, aluminum tubes, flop tube from Van's...
The tank did fiberglass of 9 gallons with a breakwater and valve (as the tank)
The liquid is mineral oil.
The pump is a Holley competition fuel pump.
The smoke you see between the two exhaust pipes is generated in that area (turbulence) again get oil smoke. It also does something weird with the oil vent oil system for inverted flight
The picture was taken on Sunday at the airshow of 25 de Mayo, Buenos Aires, Argentina, by Gabriel Luque expert photographer, I encourage you to view your photos on page http://www.airliners.net/
Roberto
