Old 12-05-2012, 11:43 AM
Buggsy2's Avatar
Buggsy2 Buggsy2 is offline
Default Tip-up canopy gas strut nuts: how??
RV-9A, but this should also apply to the RV-7 series. How can I get the nuts onto the aft gas strut flush screws?
As the plans show, these two washers/nuts are inside the aft canopy deck; I can't even get them on with my fingers, let alone tightened with a wrench. What did you guys do?
Ralph Finch
RV-9A QB-SA
Davis, CA
Old 12-05-2012, 11:47 AM
N941WR's Avatar
N941WR N941WR is offline
It is real simple
(Click to enlarge)
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-05-2012, 12:04 PM
Buggsy2's Avatar
Bill: YOU are the MAN.
Never woulda thought of that. Thanks.
RF
Ralph Finch
RV-9A QB-SA
Davis, CA
tmbg's Avatar
tmbg tmbg is offline
Clever. I punted and installed rivnuts
Ian
Old 12-05-2012, 04:09 PM
bruceh's Avatar
bruceh bruceh is offline
I did similar to Bill.
You will need to get one size longer screws than the plans call out.
Bruce Hill
2020 VAF donator
Old 12-05-2012, 08:11 PM
N941WR's Avatar
RF
Thanks, like many tips I did not invent this one but took someone else's suggestion. All I did was document it.
Bill R.
SC86 - Easley, SC
Old 12-06-2012, 05:16 AM
BSwayze's Avatar
BSwayze BSwayze is offline
Default If you don't have nutplates handy...
Here's a little trick that made this very easy for me, after frustrating myself for a while first. This is so simple. I ended up putting a sticky substance on the tip of my finger. I actually used a dab of honey out of the honey jar in the kitchen. I figured it's a harmless substance, and you get to lick your fingers when you're done! The washer stays stuck to your fingertip long enough to reach under and around the bottom flange and slip it on the screw. For the nut, I held it sort of between two fingers and managed to get it in place and turn the screw to get it on. You can also see my little 5/16" open-end wrench that I was able to slip underneath to hold the nut while I tightened the screw from the outside. Once I had this method figured out, I was able to get them on without too much difficulty.
Here's the finished installation...
Bruce Swayze
RV-7A Standard Build
http://www.BrucesRV7A.com
Old 12-06-2012, 05:19 AM
tmbg's Avatar
Bruce, FuelLube works excellent as a washer-stickin'-agent.
Ian
Old 12-06-2012, 05:37 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
But it doesn't taste as good!! I used double sided tape on my finger tips.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 12-06-2012, 06:59 AM
tmbg's Avatar
Roberta
you're not wrong about that! However, I have noticed that it smells like cheetos.
Ian
