Old 12-05-2012, 09:32 AM
taildraggers taildraggers is offline
Question LED landing lights
I was given a set of landing lights (LED) made in China, to replace heavier halogen models. When turned on, I get a lot of static, similar to squelch break, on any radio frequency I have tuned. How might this be fixed? I tried a capacitor installed between the power and ground wires at the light, with no effect.
Old 12-05-2012, 10:39 AM
tmbg's Avatar
tmbg tmbg is offline
Have any information on the lights?
It's probably a poorly designed switching power supply that's emitting tons of stray RF.
Ian
Old 12-05-2012, 11:46 AM
jdeas's Avatar
jdeas jdeas is offline
Default May not be possible
Try using a choke on the power feed right next to the device. If it has a ground line you can also try doing both through the choke.
This should help but may not fix the problems caused by a bad switching supply.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
Old 12-05-2012, 05:28 PM
BillFear BillFear is offline
Default had same issue
I tried building a choke but it did not work. finally had to remove the current controller and replace with a resistor, totally quiet now. Do a search on MR16 LED lights and you will find the old posts.
Good info on this site:
http://www.ledsupply.com/reca.php
Bill Fearheiley
Lake Norman, NC (14A)
RV7a N705RP (no longer own)
Contribution in for 2017, money well spent
