Old 05-19-2014, 08:47 PM
Originally Posted by SeanB View Post
Allan,
Please make something like this:
This is what I fabbed for my 7a. It took three hours start to finish. I used
a four inch long piece of Heavy MS grade 1 1/2" X 1 1/2" angle. I don't recall the gauge of the aluminum though.
https://plus.google.com/photos/yourp...25031269905364
Regards
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
Old 05-19-2014, 09:13 PM
sirlegin's Avatar
sirlegin sirlegin is offline
Yes. I'm in on the bike rack. I already have nice bikes and don't want to shell out for the folding ones as there's no room left for anything else.
Nigel
RV9A-N113SQ
52F
Old 05-19-2014, 09:22 PM
flightlogic's Avatar
Alan... after hacking away at a refrigerator dolly... to scavenge parts for my short little wife to reach the pedals.... I am thinking that your thinking would undoubdtedly be prettier. Was that a convoluted sentence? YES.
At any rate, if the idea makes the list, let us know.
I will be first in line to buy a set.
Old 06-09-2014, 12:10 PM
fl-mike's Avatar
fl-mike fl-mike is offline
A machined fuel tank sender/access plate and ring that uses controlled compression o-ring seals. (top-hat shape with o-ring in a groove around the cylinder).
Attach screws go into blind holes in the ring, so no sealing needed on those. Use drilled socket-head cap screws to secure the plate, and run a lock wire around the group to secure. Only sealing required would be for the ring that gets riveted on (like the fuel filler flange).
Or, something like that.
Mike W
Venice, FL
N164WM
Old 06-10-2014, 10:12 AM
Neil Neil is offline
Default Steps
Alan -- before I install the poorly made steps from Vans on a 9A, I would really be keen to purchase some well designed and manufactured steps that were not prone to failure after a few months of flying.
Judging from the number of failures of the current faulty batch, it seems with some decent engineering, many people would benefit from your quality.
Old 06-10-2014, 06:55 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Wrench for A model spar nuts
It is very difficult to get a wrench on the nuts on the lower spar bolts on 7A & 9A models (maybe others also). The landing gear weldments get in the way.
A custom wrench that would hold all 4 nuts at one time would be a big time saver.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Jacksonville, FL
Old 06-10-2014, 08:15 PM
Joness0154 Joness0154 is offline
Remove the "A" from the equation and problem solved
RV-7 builder
Old 06-11-2014, 12:18 AM
Bavafa Bavafa is offline
Just like many other things in avaition, this would only move the problem to other areas
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 06-11-2014, 12:27 PM
FresnoR's Avatar
FresnoR FresnoR is offline
I will second this suggestion.
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
Old 06-11-2014, 12:45 PM
bhassel's Avatar
bhassel bhassel is offline
How about a canopy latch kit for the RV-12...
Bob
Bob Hassel
NM
Subscription Paid for 2020
Home is where the hanger is...
