Old 01-05-2014, 08:05 PM
PerfTech's Avatar
PerfTech PerfTech is offline
Default Sounds Great!
Originally Posted by ArVeeNiner View Post
I'm finding that I only use my handheld GPS for driving the AP. I use my iPad Mini for all my charts and airport info. It sure would be great to have a cable that plugs into the Mini which will allow the use of the GPS data stream to drive the AP. That would free some panel space if I could eliminate the handheld GPS.
Out of my area of expertiese, but sounds like a great product! Thanks, Allan..
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 01-06-2014, 03:12 PM
gclark gclark is offline
Default Seat back mods
Alan, you are just great at modifying existing RV parts. I have recently seen some mods for lowering the back of the seats on the 6, 7 & 9. This is a very useful mod and enhances cabin space and accessibality in flight. Could you set up jigs to lower top of the seat back and reinstall the adjustment flap? I think there would be much interest.
Old 01-06-2014, 03:51 PM
PerfTech's Avatar
... I was reading the thread on this subject and thought "This looks like a great little modification". So off to the airport I went with every intention of retrieving the seat backs and doing this to mine. I was amazed to find that they only rose above the crossbar about 1&1/4" with the seats in there rearward position and our "Almost a 14 seat mod"installed in my RV-9A (not really worth it on mine). I haven't had a chance to look at all models to see the difference and evaluate the benefits. I did see a stock RV-6 and the seats really are tall in comparison, it would surely gain space and access from this mod. The tip-ups are more limited with baggage area due to the roll bar and the would gain as well. I will look at the others and report back soon. Thanks, Allan...
Allan Nimmo
AntiSplatAero.com
RV-9A / Edge-540
(909) 824-1020
Old 01-06-2014, 04:37 PM
wirejock's Avatar
wirejock wirejock is offline
Default drift pins
I would love a set on drift pins when available.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 01-07-2014, 04:30 PM
ron sterba ron sterba is offline
Originally Posted by PerfTech View Post
This looks like a good idea and we will have a look see. Thanks for the input. Allan....
HERES ONE FOR YOU ALAN. MAKE A ELEVATOR TRIM WHEEL assembly to fit just behind my fuel selector in my RV9A, maybe 6"- 8" .Between the seats. Push forward or rotate aft in wheel travel. Maybe even use the Vans supplied trim tab cable.
Ron in Oregon
EAA 292 Independence Oregon.
Old 01-08-2014, 06:43 AM
Nitty's Avatar
Nitty Nitty is offline
Default +1 Vote
I'll second that one
Originally Posted by Daniel S. View Post
How about a mod that actually "seals" the the front lip of the tip-up canopies on the 6,7,9?
RV-14 Build in Progress
KNYL
Old 01-08-2014, 09:50 AM
Lote Lote is offline
Default #3 cylinder cooling
Allan--I think you mentioned once you were working on a solution to the #3 cylinder cooling problem. Are you still working on that? --LeRoy Johnston RV6A "Esperanza" 780 hrs
Old 01-08-2014, 12:13 PM
cjhammes's Avatar
cjhammes cjhammes is offline
Default Bent stick
Likely still some reasonable demand for a bent RV8 stick and possibly with proper hole at base to route wires from grip.
Charlie Hammes
RV-8, N525RV Flying
RV-8, N208CH in process
Old 01-08-2014, 12:28 PM
Bavafa Bavafa is offline
I was thinking of a small gadget to keep the rod end bearing that gets attached to the flap actuator from ever coming loos. Vans solution is to drill a small hole and safety wire this but it has been to variable type satisfaction and result. I know what I would make if I had access to a some fancy equipment to mill a gadget which I am sure it is not hard to imagine.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 01-08-2014, 03:52 PM
How about a tool that lets you torque the rod-end jam nuts on the tail? For extra credit, make it so that it works while the rudder and elevators are assembled to the stabilizers.
Dave
