01-09-2013, 10:34 AM
Trim Mod!!!
I second this request.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
01-09-2013, 11:40 AM
RV 4 Canopy stay
Hi Alan
How about an RV4 Canopy stay. I have seen several different methods perhaps you can come up with something that has universal appeal???
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
01-09-2013, 02:53 PM
canopy guide
Originally Posted by SeanB
How about a set of Delrin or similar guides for the tip up canopy to nest into when closing? I've seen several builders use these at the bottom of the rollbar. Seems to be a good alignment aid.
this work for you?
http://www.bullerent.com/CanopyGuide.htm
Larry Buller
RV7A slow build, Tip up, IO360 200hp, Catto 3 blade, Dynon Skyview, arinc 429, ems, SV transponder, Garmin GNS430w, Aera 560, Dynon D6.
FLYING!
01-09-2013, 05:10 PM
Trim Mod!!!
The Location for the worm gear trim mod might work better oven on the left side of the pilot again down below the floor pan. This location might be favored by the center console side by side RVs like mine. Presently my console is modified to be able to get to the manual trim, but inconvenient.
DRRhodes
2020 VAF Supporter
RV9 N908DR
01-09-2013, 05:28 PM
Alan,
I just spent several days making and installing sheet rubber seals for where the flap rod exits the fuselage and where the wing attachment fittings exit. They are held in place with an aluminum ring that is pop riveted to the skin. These were for a Midget Mustang, but I wish I had installed some on our RV-8A ten years ago. I am still looking for an aileron rod seal in the shape of a bellows for the in and out movement. Lancair makes an aileron bellow seal, but the price is astronomical! We fly all Winter long and I know these would eliminate a bunch of drafts.
Hope these ideas are suitable for some new products.
Jim
01-09-2013, 06:04 PM
I really good aileron push tube boot is an arm or leg out of a cheap painters suit. Held on the tube with a nylon tie and an AL ring in the fuselage.
01-09-2013, 09:34 PM
Rudder spacers
I added carpet to my RV-6 (1" hard foam + 1/4" thickness of carpet) and now the bottom of the hanging rudder pedals are hitting too low on my feet (in the arch). This tends to cause pushing on the brakes when landing. How about a spacer at the bottom that also raises the contact point up 1". All the other solutions just space your foot away and does not raise the top of the contact point.
Frank Smidler
N96FS, RV-6
Flying 1/11/09
1085 hr
2WI6 Stoughton, WI
Formally of Lafayette, IN
01-09-2013, 11:32 PM
Allen, how's the wing pins coming? The ones used for temporary install..
Tyler Arnold
Iowa, La
Piper Colt
RV-4 wings and empennage
VAF Supporter! 2012, 2013
02-13-2013, 04:44 AM
if you can do this then you are a real winner!
a proper bore scope to inspect our cylinders for under $150!!!
i will be first to buy one and i am sure you can get it done by the end of the year. thanks for all your great products.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
01-05-2014, 03:06 PM
I'm finding that I only use my handheld GPS for driving the AP. I use my iPad Mini for all my charts and airport info. It sure would be great to have a cable that plugs into the Mini which will allow the use of the GPS data stream to drive the AP. That would free some panel space if I could eliminate the handheld GPS.
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
