Old 12-03-2012, 11:54 PM
Michael Burbidge Michael Burbidge is offline
Default RV-9A Michael Burbidge
Tonight I finished fitting the cowl. All the hinge wires went in without too much trouble. The fit is pretty good. On the top cowl, right side the cowl to fuselage gap is larger than I would have liked. It's about 1/16". The left side is much closer fit and looks nicer. Overall I'm pleased. I don't know how many times I took the cowl on and off to get the fit right. I got very good at doing it myself.
This feels like a huge milestone. Bigger than almost anything else I've completed. I'm not sure why that is. But it just feels like I can see light at the end of the tunnel. It's probably just a flashlight.
I'm getting excited!
Here's a couple of pictures. I bought the hinge wire with the welded clip from Vans. Very nice and worth the $26.
And the clip.
Michael Burbidge
Sammamish, WA
RV-14A Wings
RV-9A Flying 390 hours!
Last Donation: December 2020
Old 12-04-2012, 12:26 AM
You got good fit Michael. Nice very nice. It will get easier from this point.
Old 12-04-2012, 03:04 AM
Alex_K Alex_K is offline
Nice work! I'd suggested you to make a little gap ( approx 2/32" )between both cowls and fuselage for easier installation after painting.
Alexander Kochetov
RV-9A
Flying
Old 12-04-2012, 06:55 AM
Captain_John's Avatar
Michael,
Looking great! I am right there with you bruthah!
I am epoxying fasteners as we speak!
Serious MVP (Major Visual Progress)!!!
CJ
RV-7 Flying - 1,400 Hours
Old 12-04-2012, 08:04 AM
terrykohler terrykohler is offline
Default You're Going to Need That 1/16" Gap - On Both Sides
As mentioned above, it's difficult to fit together two surfaces with zero tolerance. More importantly, two painted surfaces vibrating against each other will result in chips and perhaps worse. I sent a very tight fitting cowl to my painter. He "fixed" it by using a piece of hacksaw blade and working it along the seam to create a uniform gap before painting. Still looks good after 7 years/800 hours.
Terry, CFI
RV9A N323TP
Old 12-04-2012, 08:17 AM
mculver's Avatar
mculver mculver is offline
Wow -- you are rocking along!
-- Mike Culver;
RV-9 project sold but details of the build at
www.mculver.com
Old 12-04-2012, 08:21 AM
Yes, I used exactly the same tool to make a gap before painting.
Alexander Kochetov
RV-9A
Flying
Old 12-04-2012, 08:53 AM
Default Gap
It seems like it would be easy to nick the hinge with a hack saw. No?
Thanks for the reccommendations about the gap.
Michael
Michael Burbidge
Sammamish, WA
RV-14A Wings
Old 12-04-2012, 10:02 AM
flyboy1963's Avatar
Default ...on the 'wish list'
no, not a wish list for Santa, but every time I do my preflight, i REALLY wish I had an 'oil door' on the OTHER side of the cowl.
yeah, I know...NOBODY has this, right?
well, I really hate having to peer into that black hole thru the oil door, and pretend that I know my engine is ok.
or.....what if you wanted to charge the battery?
.....cowling has to come off.
jump start?
.....cowling off?, no, wait, that doesn't help!
I suppose it really depends on what accessories you have on the 'other' side, but anyway, just my two cents worth.
......hate not being able to flip a latch, and expose the entire engine.
end of rant. Your pink lady is looking mighty nice!
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 12-04-2012, 10:10 AM
Michael
I scratched the gap between two cowls and between cowls and fuselage by a piece of hacksaw while the cowls were installed like on your picture. The gap thicknes = the thickness of hacksaw. So, I've never had inconveniences with removing/ installing painted cowls before a flight day.
Alexander Kochetov
RV-9A
Flying
