Old 12-02-2012, 09:36 AM
erikpmort's Avatar
erikpmort erikpmort is offline
Default How much vertical
Just curious, how much vertical can you get out of your rv ? Post your config and number
Old 12-02-2012, 10:06 AM
mv031161's Avatar
mv031161 mv031161 is offline
Which RV? What engine? propeller?
Mitch V.
Semi-Retired in Tybee Island GA
2007 MX2 Nigel Lamb EX RBAR MX2 (Current)
2020 MX2 New Kit Position (Sold at OSH to Team RV Member)
2009 Team Rocket F1 (Sold)
2008 MXS Green Slime"(Sold)
2007 MX2 Patches" (Sold)
1999 Giles 202 "Primal Fear/Perucho" (Sold)
1965 PA32-260 "God Bless America" (Sold)
2003 RV6 "Airhawk One" (Sold)
Old 12-02-2012, 10:21 AM
At what altitude? Weight? OAT? Close to Class A at nearly full gross I barely get 200 fpm.
Old 12-02-2012, 10:32 AM
Rupester Rupester is offline
Default OK ...I'll jump in ...
Flying solo with full tanks I'm consistently seeing +1600FPM at 90-95kts at 50 to 70F OAT.
... A fellow 9A driver with an IO-360 tells me +2000 FPM is no problem.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 12-02-2012, 10:40 AM
erikpmort's Avatar
Sorry, I'm asking for vertical, as in how many feet you can climb straight up before you stop. I understand people's numbers will vary just post what you have experienced. Entry speed alt etc
Old 12-02-2012, 12:21 PM
WillyEyeBall's Avatar
WillyEyeBall WillyEyeBall is offline
Talking vertical versus airspeed
Erik,
I determined the vertical height in a hammer head versus entrance airspeed awhile back, but can't find the data. Aircraft is an RV-4, 160 hp, fixed Performance prop, max rpm 2750 WOT, entrance altitude 2000 feet AGL, 4 G pull to vertical. Airspeeds varied from 110 to 160 knots. The max vertical at the top of the hammer head was about 1100 feet at 160 knots rotation speed. I also saw 7000 ft/min on the VS with the Dynon.
Bill McLean
RV-4 slider
Alabama (roll tide)
Old 12-02-2012, 12:48 PM
erikpmort's Avatar
Perfect thanks for posting.
Old 12-02-2012, 01:44 PM
mv031161's Avatar
Hey Bill what are your contest plans for 2013?..see you soon my friend! I enjoyed your last video
Mitch V.
Old 12-02-2012, 07:09 PM
fixnflyguy fixnflyguy is offline
Default Good info
Thanks Bill for that PIREP...I have a 160 HP RV-4 and was wondering the same. Great data from someone who knows from experience.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 12-02-2012, 07:13 PM
erikpmort's Avatar
Who else can post their number ? How much altitude do most people use for a loop ?
