Do you think this contactor (and ANL base) layout will work? The master and starter contactors are in Vans standard locations. I'm trying to figure out where to put the ground power contactor and ANL fuse base. And what would one consider the length limit of using a copper bar to tie the master and ground power contactors before using heavy cable instead? Comments?
