Old 07-18-2006, 11:11 AM
idleup idleup is offline
Default Fuel Level Sender Question...
I have a SW 385B-F Fuel Level Sender (The one that comes with the RV-7 kit). It says that when the range should be 260-32 Ohms but mine reads 247-30 Ohms. Is that still within acceptable tolerances? The other sender reads almost exactly the spec'ed range... just wondering if it makes any difference at all.
Matt Johnson
RV-7A Finishing Kit
http://www.rv7a.com
Old 07-18-2006, 01:38 PM
Mathew Sharp's Avatar
Mathew Sharp Mathew Sharp is offline
Talking
What instrument will you be using those senders with?
Our FL-2RA instrument can operate between 90 and 270 Ohms.
You can "map" up to nine calibration points along this scale, and assign "slosh" filters. I am unsure how other quantity guages operate.
Mathew Sharp
EI Tech Support
www.buy-ei.com
877-318-6060
Old 07-18-2006, 02:38 PM
lrfrey lrfrey is offline
That's about as good as it gets... Remember, fuel gages give you an idea of how much fuel you have and sometimes a good feeling... but time and burn rate don't lie. IMHO
Larry
Old 07-19-2006, 09:56 AM
+1!
Mathew Sharp
EI Tech Support
www.buy-ei.com
877-318-6060
