11-28-2012, 03:08 PM
tank sump o-ring
Hey ya fellas, a couple questions. I got a weeper on my right tank sump drain. I know the part num. is CAV-110. Can anyone give me the part number of just the o-ring or orings? It's leaking internal, and not from the threads. Also, what size of bolt threads into the tank, while I clean the old part, to plug the tank?
Is it worth to replace the entire assy, or just the o-ring? I'm creating an order from Spruce and want to get in on the way. Thx folks, DM
11-28-2012, 03:16 PM
been here awhile
You need a 1/8" NPT pipe plug (these are not bolt threads) and the plug is part of my flight kit in case an o-ring starts leaking while on a trip (it will happen). CAV-110 is the o-ring part #, $0.35 each from Vans or exchange a soft drink for an o-ring from a local A&P.
11-28-2012, 03:30 PM
I know the part num. is CAV-110. Can anyone give me the part number of just the o-ring or orings? Thx folks, DM
Order MS29513-006 from Spruce or others. Looks like ACS has a new web format so click accessories tab to get to o-rings.
http://www.aircraftspruce.com/catalo...ges/safair.php
SAF-AIR product info found here
http://www.mcfarlane-aviation.com/pd...%20Catalog.pdf
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
11-28-2012, 03:31 PM
Fuel Tank Quick Drain o-rings: MS29513-006.... This part I have saved from another post on VAF: (Viton o-rings from McMaster-Carr P/N 9464K11, size 008)
Brian Kilby
flying RV-6A, previously flying RV-9A
based at KCTJ, Carrollton, GA
11-28-2012, 03:54 PM
Unless it's really old it probably just has some debris in it which causes them to leak.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
11-28-2012, 04:22 PM
Senior Curmudgeon
Get another drain, and a few spare O rings.
Carry them with you in the plane.
When you have a leaker, just switch out the drain complete with a new O ring in it.
Leave the fuel filler cap on, and there will be a minimum of mess with fuel leakage as you switch units.
Dont forget a bit of Gas Tite/Fuel Lube on the threads.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
11-28-2012, 04:27 PM
Concurr! My slow drip disappeared once I flushed it a couple times by collecting a couple nice healthy fuel samples. Keep a couple o-rings handy in your x-cntry tool kit though.
erich
11-28-2012, 04:46 PM
fuel sump drains
FYI Saf-Air fuel drain valves are also available in STAINLESS STEEL, and eliminate the rust on the outside and on the inside (which will cause leaks). Just ask for CAV-110SS. Gene
11-28-2012, 06:59 PM
I'm lost....if it isn't a threaded plug, how does it stay in the tank?
CAV-110 is the part number for the assembly, not the oring. I'm looking for the oring part number and I'm thinking it is this...
MS29513-006. I'll grab some of these rings with a new drain, and some lube. Thx
11-28-2012, 07:12 PM
Ok, this is what I'll do. Where do you buy the GasTite product? A quick google search revealed notta. Thx Mike
