Solved
I tried a flow check right after the flow sender and still got 4.6 gph. Talked with Mike at Dynon and the only thing he thought was to remove the sender and see if some foreign object might be hanging up the impeller. When I re-installed I realized I had it reversed as far as in and out of the sender is concerned. Reattached correctly and now I get fuel flow of guess what 4.6 gph. User error once again, actually only partially.
My fuel pressure reads .6 when boost is off and 29.2 on, Mike had me check OHM between wire stud (with wire off) and the case and it is high. He thinks it might be a bad sensor. He trying to see if he can get me another to try so I don't have to buy a new one. Unfortunately they don't carry this type sender for fuel pressure anymore! At least he is making an effort to help me out! Going to go over things once more to make sure the pressure sender is not a user error issue.
I am glad to be the fool publicly so those after can just read the fix and not embarrass themselves.
Cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Reason: Fixed major spelling errors, darn those iPhones
