Old 11-26-2012, 10:40 AM
digidocs's Avatar
digidocs digidocs is offline
Question Back rivet plate setup advice
Hi there,
Up until now, I've been back riveting with the plate just sitting on my bench, and I feel like its time to upgrade to a "flush mounted solution". Two questions:
1. Where on your bench did you install (recess) your back rivet plate, and how do you like that position?
2. Is there an easy way to tell whether or not you're still over the plate other than picking everything up and looking underneath?
Thanks!
Old 11-26-2012, 11:03 AM
Question #2 reveals one of the habits of the flush mounted plate. I've done it both ways. Early on I flush-mounted it but by the end of the build, it was just sitting underneath the work.
When it was flush mounted, however, I drew extended lines out and up from its edges so that I could tell if it was on the plate. Even though I did that, however, I still picked it up and confirmed -- a habit, by the way, that would stand you in good stead.
I really don't think there's much to be gained by the process, and , besides, nothing tells you you're off the edge like a backplate sitting proud on the table.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 11-26-2012, 11:15 AM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Unless you're going to start mass producing, it may not be necessary to spend the time to recess the plate; not to mention being bound to the selected location.
What I did was get some osb board (1/4" I believe)(plywood, Masonite, whatever.) cut some strips and used it to build up the elevation of the table adjacent to the plate. I even put a few layers of masking tape on the backside of the plate to get it exactly flush with the board.
My workspace was limited to two EAA tables so moving the plate was necessary and I could arrange the board and plates to suit
Either way, when building flaps and elevators, setting the plate flush with the adjacent surface will eliminate at least one risk in making a straight and true surface without twist.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 11-26-2012, 12:02 PM
WAM120RV WAM120RV is offline
Default Flush mounting.
I got two pieces chip board the same thicknes as the plate, about 2 feet by 1 foot and cut the shape of the plat out of one of them. The two boards are glued together and board with the hole sits on top of the other, with the plate sat in the hole.
You can still move it about, take the plate out, but it does offer more support to panels.
Always check you are on the plate or you can wreck a skin!!
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
Old 11-26-2012, 12:15 PM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
Like others, I chose not to embed it in my bench. I like being able to orient the bar as needed. I also use a 1/4" piece of press board (I think I got it for a drawer bottom originally) and it keeps everything flush.
7 rivets is all I do per "run". I orient my plate how I need it and rivet 7 rivets. I know that if I go 8 I'll still be OK, but 7 allows for a good safety margin. I then scoot the plate and repeat. If I try to do 9 rivets then I have to stop the process and go call Vans.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
Old 11-26-2012, 02:14 PM
N15JB N15JB is offline
You can use a magnet on the upper surface of the piece being riveted to determine if you are over the backing plate, but it is just as easy to look.
Jim Berry
Rv-10
Old 11-26-2012, 04:04 PM
claycookiemonster's Avatar
claycookiemonster claycookiemonster is offline
Default Carpet remnant!
I got a carpet remnant about the thickness of the back rivet plate, cut out a spot for the plate and tacked it to a larger piece of scrap - like a piece of the delivery box. Actually, if the carpet holds the work a tiny bit above the plate there'll be fewer chances to scratch your work, but as you press down with the back riveter, you'll be able to tell if you're on the plate by the solid resistance you feel.
Clay "Cookie Monster" Cook
recently returned to lurker status
