Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 11-26-2012, 05:07 AM
pierre smith's Avatar
Default A favor from 430W owners?
Mornin' guys. Yesterday I flew my stepson/Marine back to Camp LeJeune, N.C. and when I pressed the "Proc" button, to select the RNAV Rwy 23 approach, it was not available in the selection drop-down tab. I scrolled up down and would have gone sideways but I could not get the option for RNAV 23 to show at KOAJ.
Next time one of you guys boots up your 430 W, would you enter KOAJ and see if you can see the RNAV/LPV 23 approach? My data card expired in May and is more-than-likely the problem. New one's on the way.
A good reason to print a paper copy before departure on an IFR flight, even tho' it was CAVU yesterday.
TIA,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 11-26-2012, 05:11 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Pierre
I update ours every month, legally to fly an IFR approach we have to.
Be careful man!
Not that you will crash....just the FAA
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 11-26-2012, 05:28 AM
rwhittier rwhittier is offline
Default Expired DB
The original plate was issued 31 may 2012. You nailed it, database issue.
Roger Whittier
RV7A Quick Build, Tip Up
N1MY Reserved - Canopy finished - Wings mated, Engine hung, electrical 95%
Old 11-26-2012, 06:19 AM
sailvi767 sailvi767 is offline
Pierre, I fly in their often since my daughter lives nearby. I think that is a new approach. I only recall seeing it the first time in Aug.
George
Old 11-26-2012, 07:31 AM
George
Yeah, it occurred to me that new approaches are constantly being added and it may not have been in the May database. The lesson learned tho' was to do this availability check BEFORE you get in the air. I was on an IFR flight plan and cancelled before I needed the approach, then, in my mind, "What if" I needed that approach?
My iPad's Skychartspro has the approach but it would be a bugger to fly with it not available in the 430W.
Thanks guys,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 11-26-2012, 08:25 AM
dmaib's Avatar
dmaib dmaib is offline
Seems to me there was a post a while back about not all approaches being in the Garmin DB for some reason. Anybody remember that? At any rate, you are right, Pierre. Best to check before you go. I almost always print paper plates when taking a trip.
Also, I don't think you can legally execute an RNAV IAP unless it is in the DB, so the Skychartspro option would not even work.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
Old 11-26-2012, 09:36 AM
Default Really?
Dave, the rwy 23 approach is also listed on Airnav as a current approach.
So, you're saying that it would be illegal to create a route with the listed intersections on the approach plate, into the 430 and then fly THAT approach? Correct? RAIM issues?
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 11-26-2012, 10:22 AM
Radomir's Avatar
Radomir Radomir is offline
What David said
You wouldn't get proper scaling... you have to load it from DB to do the approach legally..
Radomir
RV-7A sold
Old 11-26-2012, 10:51 AM
turbo's Avatar
turbo turbo is offline
i believe it would get you on the ground safely if the waypoints were in the db, but in hot dudu with you know who if you had some 'issues' that day.
anyways, may to nov with no new db. find someone running 430w and get a month old card.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 11-26-2012, 12:50 PM
Above are correct. FAA rules require all fixes used for an approach to be retrievable from the unit's database. I think they are just worried that one mis-entered digit in the lat/long could be a disaster. And the database is supposed to be current.
These rules do not apply to enroute use. Enroute you may use an expired database as long as you verify that the lat/long's are still correct for all the fixes you use. (Who does that?).
