Hi Guy
I need some advise with grounding my mgl efis backup battery.
From the install manual it states that during normal operation the EFIS will charge the backup battery.
I want to use the backup battery to run a backup bus for the boost pump and efis ect.
My question is can I just ground this battery against the common ground on the firewall where the main battery is grounded? Will it still charge the backup battery this way?
