Old 11-22-2012, 10:31 PM
bret's Avatar
bret bret is offline
Default Which band saw?
Tooling up for the fuse-finish kits and wondering what band saw folks went with. And what blade, I heard a wood blade for aluminum ?
Old 11-22-2012, 10:46 PM
ColoRv's Avatar
ColoRv ColoRv is offline
I have a harbor freight bench top cheapie and it works just fine with the blade it came with on any aluminum that I've attempted.
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
Old 11-23-2012, 04:13 AM
donoltman donoltman is offline
Default bandsaw
I bought the SKIL from Home Depot with a metal blade. I think is was just over a hundred dollars. But the feature that I love on it is the laser light that projects a line in front of your cut.
Don
Old 11-23-2012, 04:46 AM
rleffler's Avatar
rleffler rleffler is offline
There isn't much difference with the inexpensive saws found at the local retailers. I bought a ryobi which worked well, but blades were hard to find. Fortunately, there are places on the net to get custom blades made that are inexpensive.
Most of these also have 9" clearance between the blade and the body of the saw. This created a few situations were I had to get creative to make the cuts. With that said, while a larger bandsaw would nice, I'm not sure it's worth the expense.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 11-23-2012, 05:11 AM
Wingnut Wingnut is offline
I was fortunate to find the 14" Rigid bandsaw at a Home a depot that was selling them off as they were no longer going to carry them at that location. I got it for 1/2 price (about $180 IIRC). Unfortunately, they no longer stock the 93.5" blades there. I'm hoping that Lowes has them in store. The wood blade works well for aluminum. I was able to pick up the Rigid drill press in the same manner. Both have worked extremely well (wish my 30 gal Kobalt air compressor had lasted more than two years!).
Con Kelley
RV7
Empennage and wings need tips
Fuselage kit "finished" (for the moment)
Finish kit and FWF in progress
Hartzell CS
Aerosport Power IO-360, Dual Pmags, AFP FM200 FI
Hangar construction at 7FL4 nearly finished.
Home construction at 7FL4 about to begin.
C-172 at KCRG (sold)
C-150 at 7FL4 (sold)
www.mykitlog.com/cakelley
www.1379.eaachapter.org
Old 11-23-2012, 07:02 AM
larrynew's Avatar
larrynew larrynew is offline
My 10" Craftsman with the blade DanH recommended has worked great.
http://www.vansairforce.com/communit...4&postcount=14
Larry New
RV-7A - Flying 900+ hrs
RV-10 - Flying 2.9 hrs
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 11-23-2012, 07:06 AM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
Check on Ebay for a good 14" bandsaw. I have been in woodworking for 50 years and found this is the best value for the buck. Whether it be a Delta or off brand will not make much difference but you will find this size is suitable for most woodworking or metal cutting that you need to do. Look for at least a 1/2 HP motor or larger so that you can change blades from anywhere from 1/8" to 1/2" with no slowdown. Use a metal cutting blade for metal and a wood blade for wood. Extra blades can be ordered to size from my favorite shop in Miami called Smith Hamilton Shop. Ask for Valerie and tell her Roger sent you.
Old 11-23-2012, 07:43 AM
aarvig's Avatar
aarvig aarvig is offline
I bought the biggest bench mounted Craftsman and went with a custom made 18TPI blade that was 1/4 inch wide. Works great for me. The custom blades I had to have made through a local saw shop...9 bucks a piece (Twin Cities Saw). You need a higher TPI to work with aluminum and you need the blade thin enough so you make make corners relatively easily.
Good Luck...
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
Old 11-23-2012, 07:46 AM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
Although a lover of fine tools, I bought the El Cheapo Harbor Freight bandsaw, and it has served me well in my build, no complaints.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 11-23-2012, 07:47 AM
NYTOM NYTOM is offline
Talking Oh' the Craftsman works saw good.
I second this recommendation! I bought a 10" Sears Craftsman over a decade ago and it has worked on 99% of the cuts and I'm just about done with all the aluminum work. I agree with the blade recommendations too. A metal cutting blade with 14 teeth per inch cuts aluminum like butter and I think I used maybe four blades to date and I screwed up a couple of those trying to cut stainless or something else I shouldn't have been trying to cut with it. It's a portable table model so it doesn't tend to get in the way like a larger stand alone saw and the blades are only as far away as the nearest Sear's tool department or a Internet connection.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
