Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
Old 11-22-2012, 11:33 AM
WAM120RV WAM120RV is offline
Default Lightspeed and Sensenich FP metal prop
How many of you guys are running with a Lightspeed or other electronic ignition system with a Sensenich FP metal prop?
I am interested in the set uo you have and the hours flown with this combination.
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
Old 11-22-2012, 01:11 PM
bhester's Avatar
bhester bhester is offline
Thumbs up My Light speed setup
I'm using one mag and one Light Speed with a Sensenich FP prop on a Superior XP O-360. Just switched from a Hall Effect Sensor to the new Mini Sensor.
You can read about the latest info here on my my site:
http://home.newwavecomm.net/bobbyhester/2012Flying.htm
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 11-22-2012, 01:47 PM
Norman CYYJ Norman CYYJ is offline
Over a thousand hours with a Sensenich Fp prop and dual LightSPEED and no problems and great in low to high teens.
Old 11-22-2012, 03:01 PM
Default Engine
Thanks guys
Norman what engine are you running?
Steve Arnold
England
Old 11-22-2012, 05:15 PM
ronoc74 ronoc74 is offline
Thumbs up
I have one P-mag and one Slick mag on an XP-IO-320. Running an extra 2" of pitch over the recommended prop and very happy with the performance. It will still exceed 2600 rpm at 8,500 ft so once I go LOP it's all good.
Conor McCarthy
RV-9A 90990 flying
QLD, Australia
Old 11-22-2012, 08:59 PM
IO-360, dual LightSPEED, 87 inch pitch 2inches more than Vans calls for static 2100 rpm
Old 11-23-2012, 05:28 AM
tc1234c's Avatar
tc1234c tc1234c is offline
I have 800 hrs on one Lightspeed and one Slick mag. Magnet on flywheel for the Lightspeed. O320-D2A with standard (70CM7S9-0-79) FP Senenich metal prop. Engine start with Lightspeed.
Ted Chang, VAF #681
2018 Due paid
Old 11-24-2012, 02:13 AM
Default Building a database
Thanks Guys
For your information I am putting together a small data base to help with getting this combination accepted in the UK. Having said that it has already been done here, I think its a case of left hand right hand!!
Steve Arnold
England
