Maybe my vibration was worst
Hi
I agree with everybody but i think i had a very BAD vibration. The one that you think that the airplane will fall apart or the one that make you inspect the engine mount and firewall because you would expect to find a crack.
I had a rv-7 before and i had some vibration that i was able to deal with but in the rv-10 it was bad. It begin with just a little shimmy like in my rv-7a but went worst and worst to very BAD.
With my upper gear leg bolt loose, with time, i think i would have a structural failure. I just want rv-10 owner to check these bolt if they have bad vibration.
It was hard to notice when moving the gear leg when the airplane was on jack but it was there. Not forward and backward movement but rotation.
Now i can live with the really small vibration that i have. I may add stiffener if it bother me but i don't think it can do anything to my airframe now.
So in conclusion, I don't say that i found the vibration problem of all the RV but i found mine and i am glad because i am sure it would be dangerous with time.
Lan Vinh Do
RV-7A c-GOSV sold
RV-10 C-GMCE
Rv-7 emp completed but waiting boys to be older to help
donation 2020 done ( little bit earlyer)
