Old 11-21-2012, 02:34 PM
gereed75 gereed75 is offline
Default Engine gurus - gasket sealers
I am in the process of re-gasketing all of my accessory drive pads chasing a pesky oil leak.
Does anyone use any gasket sealers or does everyone just go naked gaskets??
Thanks and Happy Thanksgiving to all
Gary Reed
RV-6 IO-360
WW 200 RV now an Al Hartzell for improved CG
Old 11-21-2012, 02:55 PM
rocketbob's Avatar
Gaskets should never be installed dry in my opinion. Guaranteed to tear and require scraping if done that way. I rub medium titeseal on both sides of the gasket.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 11-21-2012, 03:48 PM
Walt's Avatar
Walt Walt is offline
I agree with Bob, a good gasket sealant should always be used, I use Titeseal but have also had good results with Hylomar.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 11-21-2012, 03:54 PM
drakerv drakerv is offline
Default gasket sealer
agree, Hylomar.
Old 11-21-2012, 04:15 PM
Thanks men
Gary Reed
RV-6 IO-360
Old 11-21-2012, 06:20 PM
fixnflyguy fixnflyguy is offline
Default Hylomar
Hylomar is good stuff !
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 11-21-2012, 06:36 PM
rv9aviator rv9aviator is offline
I really like Titeseal as well. Never knew about it until I built my 9a. I now use it in my mold making business to seal water lines. It works better than anything I've used before.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
