Old 11-20-2012, 01:47 PM
WingedFrog's Avatar
WingedFrog WingedFrog is offline
Default Splicing shielded wires
This was a bad day at the workshop, I inadvertently cut a wire while trimming tie-wraps. To make the matter worse, this is a shielded wire, making the repair by soldering more tricky. Does anybody can provide me guidelines and/or tips on how to proceed?
Builder's name: Jean-Pierre Bernoux
Sport Pilot
Kit # 120395 N124BX
Flying as of 9/11/2013
Builder's Blog:http://vieilleburette.blogspot.com/
EAA 1114
Old 11-20-2012, 02:11 PM
JoeM's Avatar
JoeM JoeM is offline
Default Replace it
It depends on what purpose the wire has. If it is a twisted pair or other data transmission wire (cat-5) I would replace the wire. If it is for some sort of antenna replace it. Just my opinion, I'm sure someone with more more expertise will post their opinion.
Joe Mikus
MSgt USAF Ret Avionics Tech
Perryville, MD
Student Sport Pilot
Future RV-12 Builder?
Old 11-20-2012, 03:55 PM
Mark C. Mark C. is offline
Default Splice wires
WingedFrog.... send me a PM I should be able to help you. The company I work for mfg's these kind of parts depending how bad a splice might work, but as recommended the end to end wire replacement would be best..
Mark C. TE Connectivity..
Old 11-20-2012, 06:27 PM
WingedFrog's Avatar
Thanks guys, I found that luckily this wire was unused. I nevertheless repaired it as best as I could as a kind of training. Replacement of the cable was excluded because one end was going into a connector I definitively did not want to get into. I soldered the conductor, covered the repair with heat shrink sleeve and mended the shielding with a piece I took from a TV cable. I covered the mended shield with a heat shrink sleeve again.
Sport Pilot
Kit # 120395 N124BX
EAA 1114
