11-18-2012, 08:25 AM
Help with accessory case ports
Please help identify ports on the accessory case. Engine is o-360 experimental best I can come up with hio-360A1LD
1st pic: I'm mostly sure about the locations of oil return from cooler, breather and oil pressure but what is the port used for that is plugged behind the oil pressure AN fitting?
Right side of engine in front of the oil filter. A is the port from the previous pics/questions. I'm pretty sure D is the Vernathem, it has a PMA part #. I had originally thought E was the oil to the cooler but not so sure.
Also the plugs don't seem to be NPT, they have a rubber O-ring instead. The AN fittings in Vans FWF kit for the oil cooler lines are way to small to fit, advice?
Andy
11-18-2012, 09:04 AM
IO-360-A3B6D or similar......a single dual-mag accessory case.
The books identify your mystery plug as the oil temperature well, with plug "B" as the alternate location.
"C" is shown as the oil cooler connection.
"D" is the vernatherm.
"E" is shown as the turbocharger oil drainback location.
Dan Horton
RV-8 SS
Barrett IO-390
11-18-2012, 10:49 AM
Thanks Dan!!! What reference/where can I find this online?
There are currently AN unions like these in my accessory case, Is this an approved method?
To hook up the oil cooler should I buy these reducers (AN912-8D 3/4-3/8) and use Van's supplied AN fittings (AN822-8D 1/2inch TubeO.D. 3/8 thread)? Steel?
Thanks!
11-18-2012, 02:35 PM
Unknown. I happen to have a parts manual.
The manual calls for an AN919-15 with an MS29512-10 o-ring, assuming you want to use 1/2" hoses for the oil cooler plumbing.
Dan Horton
RV-8 SS
Barrett IO-390
01-25-2013, 05:02 PM
Safety Wire?
Should these AN-919 with MS29512-10 Oring fittings in my accessory case be Safety Wired? They are not drilled, but it seems everything else (temp sensor plug, vernathem, plugs) is drilled.
Andy
01-27-2013, 06:21 AM
Bump....Should I saftey wire the AN919 with O-ring on my accessory ports? They aren't drilled, but I could drill and safety....
Andy
01-27-2013, 04:39 PM
If you're not installing a fitting with pipe threads, then yes, I would think you would safety wire these on. It won't hurt to do it although it might not be necessary. Also you might want to consider installing steel fittings especially if you are going to connect a 1/2" oil line to it.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
01-27-2013, 05:54 PM
Thanks, I was kinda thinking just drill wire and be done. My fittings are steel but the only pics I found were aluminum.
