11-18-2012, 07:17 AM
EGT probe location
I have an older analog EGT gauge that has readings for two EGT's. Is there an optimum location if you can only monitor 2 cylinders? ie, #1,#4 etc?
I do plan on getting an EMS soon but thought i would hook this up for now.
Previous owner installed new exhaust and discarded all associated wiring, probes etc.
Cheers
Wade
11-18-2012, 08:00 AM
If you are going to monitor just 2 cyls, I would recommend #3 and #4. #4 runs hottest on most aircraft, but #3 seems to always be the hottest on RVs.
If you have not drilled the exhaust and intend to add the other probes later, be sure to locate the probes at a distance that all probes can be at the same relative location from the flange.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
11-18-2012, 08:48 AM
if the question was in regard to CHTs I would agree, but since it's EGTs, I would say that it doesn't matter which cylinders you put them on. However, if you only have two CHT probes as well, put the probes for both EGT and CHT on the same cylinders and go with what Mel says. And get your engine monitor ASAP so you will have ALL the data.
erich
11-18-2012, 09:05 AM
If you are going to monitor 3 & 4, just make sure you cut down the air dams on #1 and #2 on the Van's baffle kit. Otherwise, you'll probably be monitoring your two coolest cylinders.
11-21-2012, 02:55 AM
Wade
Make sure that you pick a location that will allow the other two to be at the same distance when you add them.
Dave & Trina
RV-9A Flying  - 330 Hrs. Painted  Finishing the interior.
11-21-2012, 05:32 AM
2.0 - 4.0 inches from the head.
Make all 4 the same position and distance.
I would get that EMS fitted as soon as you can. They are worth every penny.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
03-06-2013, 10:15 PM
Position again...
Is 1 inch from the head two close? I'm installing on cylinder #3 with standard cross over exhaust. There is a bend that starts at about 1.25 inches, followed by the exhaust pipe section connector. It is either at 1.125 inces or 6 inches.
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
03-06-2013, 11:56 PM
If it can't go on the bend it will have to do, but often the bends are not that bad. Maybe your are.
Same across all is better if you can.
David Brown
03-07-2013, 10:16 AM
VAF Moderator / Line Boy
Michael-
I think that at 1", you're going to be burning up a lot of probes, especially since you have to put ALL of them that close to be consistent. Many folks have been able to place their probes in the normal range with the "Standard cross-over exhaust" - I'd very hesitant to drill holes at 1".
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
03-07-2013, 10:53 AM
Watch the angle you put the probles in. Make sure you can still get the spark plugs out. I have seen them installed in a manner that interfered with access to the plugs.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
