Old 11-17-2012, 05:26 PM
dbaflyer dbaflyer is offline
Default Gap F-7106 and Instrument Panel
I have about 1/8 gap at the widest which is at the bottom of the instrument panel outside edges. I wondered how this is going to look once the panel is complete. Is there a way to eliminate the gap?
Denis Sailer - Eastern Iowa
RV9A builder - Phase 2 (42 hours)
RV-9
Old 11-17-2012, 05:37 PM
JonJay's Avatar
JonJay JonJay is offline
Hind site 20/20, I wish I had a gap. It is a lot easier to build your panel un-mounted. If it is too tight it is difficult to install and easy to scrap paint off the underside of the glare shield/skin.
While you don't need as much gap as you have, I would file down the edge to make some gap all the way around and live with a little extra where you already have a bit too much.
Or, move on now and don't look back. You will not notice that gap after a while and nobody else will either.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
