Old 11-16-2012, 10:03 AM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Priming/painting engine baffle?
In the process of building my engine baffle.
Is it ok to prime and paint and if so do I need
a high temp engine paint? Thanks.
Al Girard, Newport, RI
N339AG
RV-9
Old 11-16-2012, 11:42 AM
rleffler's Avatar
rleffler rleffler is offline
I just did mine with white hi-temp primer and paint. As far as it being a requirement, I can't say. My thought was that it was a good idea, since portions of the baffles are in direct contact with the engine. The other option would be to powder coat, but I went with the lower cost option.
I don't know if all hi-temp paints are the same, but the stuff I used was the most aromatic of all the paints I used, including the akzo epoxy primer. It was really nasty. Since I didn't want to spend the rest of the day wearing a mask, I just left the hangar early those days I painted.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 11-16-2012, 11:56 AM
jdeas's Avatar
jdeas jdeas is offline
Default Rattle can ceramic paint
Why take the chance? I used the Dupli-Color (Pep Boys) Engine Enamel with Ceramic.
Alodine then painted. Will run/drip faster than most Rattle paints I used but almost impossible to remove after a few weeks cure.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
Old 11-16-2012, 12:01 PM
N941WR's Avatar
N941WR N941WR is offline
I did not paint mine for the simple reason that they are easy to replace, if needed and this is not a car, so I do not plan on removing my top cowl at fly-in's.
Also, if there is an engine fire, the less paint up there burning, the better. IMHO.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-16-2012, 12:56 PM
N15JB N15JB is offline
I painted the baffles in my Pitts with Imron; 25 years later still looked good. I had the baffles in my -10 alodined at a cost of $50 for everything; only 3 tears old, but also looks good.
Jim Berry
RV-10
Old 11-19-2012, 06:43 AM
yakdriver yakdriver is offline
I powder coat my engine baffles. Looks great and tough as nails. Cost was about what it would cost to paint with good materials. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 11-19-2012, 07:20 AM
Jeff R's Avatar
Jeff R Jeff R is offline
I used Rustolium engine spray paint from Wal-Mart or Home Depot. I painted them several years ago. After more than 50 flight hours, no problems noted at all.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 11-21-2012, 03:17 PM
penguin penguin is offline
I would suggest you think carefully before painting your baffles. Unless you live close to the sea it is probably not worthwhile. It will make everything look smart initially, but the baffles take a beating and (in my experience) will soon have scuffs, etc. Anyway - who will see the baffles? If you are in no hurry to finish and go fly then why not, but ...
Peter
