Old 11-16-2012, 03:49 PM
pilot2512 pilot2512 is offline
Just a thought...but you may want to start on the VS first. Much easier to build and improve your skills for the HS. I did it that way after reading some posts about it and was glad I did.
Jay
RV-9A
Empennage complete.
Wings complete.
Fuselage in progress
Wiring in progress
2020 Donation made!
Old 11-16-2012, 04:29 PM
whd721 whd721 is offline
Consider starting with one of builder training classes. I went to Synergy Air in OR. Not cheap, but a very good start with knowledgeable instructors. In a short time you have nearly completed Emp parts.
The big benefit is not completing the Emp, but the tips, techniques and good practices you pick up. I have found that almost 1/2 the task in building a Vans RV9A is learning how to rig parts, which tool works best, what tasks are "good enough" and many things that a craftsman just knows.
If you have a good friend who has already built a RV, you are fortunate. Most issues in the building process are questions with out an obvious answer. Most are fairly simple, once you have the light bulb come on.
This forum, other builders project logs, photos from others and your tech adviser will be your best friends.
whd721
RV9A
Sherwood, Oregon
As Bill Stout (designer of the Ford Trimotor) used to say, ?Simplicate and add Lightness?
