Old 11-14-2012, 10:53 PM
denbobp denbobp is offline
Default RV-8A canopy frame help
Is there any specific measurement between the front bow and the canopy frame when in closed position. My is about 1 inch apart. I haven't installed the canopy yet.
Old 11-15-2012, 10:01 AM
flyinga flyinga is offline
I don't recall a specific space limit but mine is about 1/4". Your concern with 1" spacing will be the fit of the canopy/windscreen. The canopy has a pretty good slope at that point and the frame will have to be raised enough to fit the curve of the canopy.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 11-15-2012, 03:32 PM
bird's Avatar
bird bird is offline
You want about 1/4inch or so on that. Could be you canopy frame is touching the forward skin and the aft bottom on each side, if it is trim that away flush the the bracket that gets riveted to the canopy bow, that should allow your frame to go fwd enough to just about touch.
bird
Bird
rv8 entire airframe at airport now, painting done, intersection and gear upper and lower fairings done, maybe order engine around first of year or before the next rate increase.
"to fly is a privilege that I am so thankful to God for"
http://www.mykitlog.com/tcb328/
Old 11-15-2012, 08:36 PM
The canopy frame doesn't touch anything and is alinged on both sides. maybe I have put the bow to far forward??? Once the slide goes into the drop down it just ainint going any further. any other thought swould be appreciated.
Old 11-15-2012, 08:54 PM
mannanj's Avatar
mannanj mannanj is offline
Default Frame
Not near my -8 right now, but I believe the separation on mine is closer to an inch than it is 1/4 in. Just adjust it up to fit plexi on assymbly.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 11-15-2012, 09:59 PM
bifft bifft is offline
I put my front bow too far foward, and have a 1"gap as well. I just made the front go up to fit the canopy, had to make a longer latch so as to be able to get it to close, but otherwise haven't had any problems. Not flying yet tho.
