Old 11-14-2012, 02:07 PM
rwarre rwarre is offline
Default Burned cowl
Was inspecting my lower engine cowl and found a section 1" by 5" that was black and crystallized. I assumed it was from heat but the area was not close to the exhaust pipes. It was covered with the Vans heat shield material. I sanded the area and applied new fiberglass cloth and resin. Anyone have an experience similar. Thanks
Old 11-14-2012, 02:45 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Picture?
Could it be an indication of a breach in an exhaust pipe or similar?
Did you install the heat shield? If not, there was a reason for someone placing it there.
