11-13-2012, 02:56 PM
AN fittings - quality control
I just received the two AN816 fittings I ordered from Spruce to reinstall the replacement red cube. This is the second time I've received two of them on the same order that are notably different. Coincidentally, the last time I ordered two of these (again, from A/S) the same thing happened. Anybody else notice this? Should I prefer one "style" over the other?
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
11-13-2012, 03:28 PM
Steel
Terry. In a recent thread I posted regarding
piping up my red cube. A few guys tuned in and recommended
Steel fittings.
Al Girard, Newport, RI
N339AG
RV-9
11-13-2012, 04:17 PM
Thanx, Al. It depends where it's located and whether or not it's solid piped or with flex hoses. I'm confident Al will work fine for my installation.
Terry Ruprecht
11-13-2012, 04:20 PM
You should get a genuine AN/MS spec fitting. Anything else is fraud; the staff at Aircraft Spruce should know the difference.
We had this conversation a few years ago.
Dan Horton
RV-8 SS
Barrett IO-390
11-13-2012, 04:56 PM
Both styles are allowable (my interpretation of note a)
AN816 drawing note a: "at the option of the manufacturer, the smaller diameter may be drilled through the fitting from end-to-end."
Not sure if I'm interpreting this note correctly.
11-13-2012, 08:44 PM
Are they both marked "AN"?
At one time there were unmarked fittings getting delivered through the aircraft channels...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
11-13-2012, 08:50 PM
I read it the same way...
http://www.everyspec.com/AN-SPECS/AN...-13.010280.pdf
Gil Alexander
11-14-2012, 10:37 AM
Per the Spruce catalog, the fittings are AN816 4-4D.
Referring the pics above:
The one on the left, darker in color and less shiny, has stamped marks on each of three hex sides: HK, D, and AS
The one on the right, which subjectively appears to be of higher quality, has stamped marks on two of the hex sides: RE, and AS-D
The ones I ordered a month or so ago have identical marks.
FWIW
Terry Ruprecht
11-14-2012, 07:41 PM
I am sincerely pleased to hear about marking. It sounds right....manufacturer ID, AS5195 standard, aluminum.
Dan Horton
RV-8 SS
Barrett IO-390
11-14-2012, 07:49 PM
Originally Posted by Bob Axsom
What is the ID of the holes on both sides of both fittings? The D means aluminum which is consistent with blue fittings. The AN816-4 has only two pipe thread sizes:
AN816-4 = 1/8" pipe
AN816-4-4 = 1/4" pipe
Bob Axsom
To be a bit more precise, from the Mil Spec -
1/8 NPT 0.188 in. diam +/-0.003
1/4 NPT 0.261 in. diam +0.004/-0.003
These should be the standard hole diameters for a pipe fitting.
Gil Alexander
