11-13-2012, 01:23 PM
how to combat middle-aged sag.......!!!!
okay, I guess we've all come to expect a little of that....
but, now with 100 hours, I see the conical mount on my -9a has sagged about 1/2". ( carb'ed 0-320, FP)
not a problem with the cowl touching the spinner....yet...but some preventative action is wise.....
What's the best and/or simplest way to correct this?
New lower mounts, new uppers?
Shim the lower engine mount at the firewall?
Fly inverted for the next 100 hrs???
thanks for any feedback!
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
11-13-2012, 02:22 PM
Which mounts did you use?
With my O-290 I had solid rubber mounts and was going to repace them withh Loard mounts.
The solid rubber mounts deform and just continue to deform.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
11-13-2012, 02:39 PM
wish mine would sag ...
On the advice of several people, I installed my cowl about 3/8" below the spinner aft edge, so they would align when the inevitable sag took place. The engine has been hung now for almost 2 1/2 yrs, and I now have 15 flying hours on it, but there has been no perceptible sag in the engine and spinner. So my sight picture over the nose when flying has a 3/8" annular ring view of the spinner backplate.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
11-13-2012, 03:55 PM
lord mounts....for conical?
With my O-290 I had solid rubber mounts and was going to repace them with Loard mounts.
Bill,
I only see Lord mounts to replace OEM dynafocal type biscuit mounts.....if they have something exotic for conical, I didn't find it, but their site punted me out before I had a chance to look much.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
11-13-2012, 03:58 PM
probable cause????
Terry,
you just land waaaaaaaaay too gently!
...or, try letting a couple pounds of air out of the nosewheel???
sorry, nothing but wisecracks today!
sounds to me like you could slice an 1/8" off the back of the top mount and gain a degree or two. ( Caution, it may not climb as well as it did before!?!?!)
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
11-13-2012, 04:56 PM
Lord conical mounts
Originally Posted by flyboy1963
Bill,
I had this problem on my Citabria years ago, and replaced the standard conical mounts with special conical Lord mounts. Solved the problem, lasted a long time.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
11-13-2012, 05:01 PM
I'm glad I'm not the only one with this problem. I hate it! I have over 60 hours on the plane with no perceptible sag but with an ugly site picture.
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
11-13-2012, 06:37 PM
Patience
Give us an update at 3 years and 300 hours.
Jerry, please help out here; your plane (now mine) is over 5 years old and the spinner/cowl match is perfect. How did you do it?
Dale
ATP, dreamer and maintainer; but not a builder
RV6a N18XP 960TT (builder: Jerry Cochran)
RV6a flight experience 2100 hrs
Superior IO-360 2007
Hartzell Blended Airfoil Prop
Dual LS EI, Dual Battery
GRT HX efis & RAIM GPS, 2 axis GRT autopilot
G696, GDL39 WX, Traffic
Dynon D10
Gear Leg Stiffeners from Woodmanrog
11-14-2012, 10:50 AM
Thanks for posting, Kelly!
....misery loves company.
Terry Ruprecht
11-14-2012, 12:16 PM
Hi Dale,
Before it was painted and while flying off the time, I trimmed the back of the cowling to fit better, flew some more, seemed stable so then painted same. Nothing real special the sag was minor.
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
