Old 11-13-2012, 07:29 AM
Avengerboss Avengerboss is offline
Talking Smoke systems
Looking for a nice smoke system for my RV-7, Who do you guys suggest??
Old 11-13-2012, 07:43 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
One option:
smokingairplanes.com
Old 11-13-2012, 10:55 AM
Snowflake's Avatar
Search is your friend. There is a long, recent, thread about this.
Personally I like the look of the home-brewed system that Tonyboy had on his RV-3. If you don't mind building your own, it's a great system. If you want something more turnkey, then smokingairplanes is the solution you want.
Rob Prior
Old 11-13-2012, 01:01 PM
Ron Lee's Avatar
I do not know what TonyBoy did but I have observed the output of several homemade systems locally. The major problem was the use of a clearly inadequate pump.
Old 11-13-2012, 01:43 PM
VETE76 VETE76 is offline
http://www.acroflyer.com/smoke_system.htm
just found this, dont know a thing about it.
Old 11-13-2012, 02:25 PM
snowbird snowbird is offline
Check this thread
http://www.vansairforce.com/communit...ighlight=Smoke
Greg Wilkinson
RV-9A
St. Thomas, ON Canada
Old 11-13-2012, 03:54 PM
fixnflyguy fixnflyguy is offline
Default Smoking planes
I installed the 3.5 gallon Smoking planes system in my -4 and the same system in my friends F1 Rocket this summer..we are having a blast with them. Nice kit, simple to install, and easy to remove. You can roll your own for less $$, but it was nice to just get a box of nice stuff and be done 8 hrs. later.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 11-13-2012, 04:12 PM
Tony Spicer Tony Spicer is offline
If you're into DIY, here's a simple system that works every bit as good as a SA setup for a lot less money.
Tony
Old 11-13-2012, 05:25 PM
Default Smok-in
Awesome suggestions thanks guy's. I kinda do want to build my own but i'm going to look at all options.
