11-12-2012, 06:26 AM
What's in your emergency tool kit
You're flying halfway across the country with not a lot of spare weight in the baggage area (because of luggage etc).
You've got a bag that's a little bigger than a toolbox to stuff emergency tools. You've already stuffed some duct tape in there and a replacement gas cap... a Phillips screwdriver, a flat head screw driver, and a pair of needle nose pliers in there.
What else?
11-12-2012, 06:58 AM
Originally Posted by LettersFromFlyoverCountry
What else?
You are good to go Bob just add to your toolbox some inches of safetywire and a small mirror on a stick. Flash light would be helpful too
11-12-2012, 07:20 AM
VAF Moderator / Line Boy
Whatever you need to get your wheelpants off.
Whatever you need to get your cowl off.
Electronic gadget to connect to the internet to call for VAF help!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
11-12-2012, 07:23 AM
A spare tire tube is a must have! That's saved my bacon (and others I've been on trips with) three times over the years.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
11-12-2012, 07:26 AM
After making a couple trips abroad and after having found (luckly in my hangar) one main wheel down, I decided to add:
- a spare nose tube;
- a spare main gear tube;
- some mixed screws (fairings and cowl: I lost a couple of screws from fairings during 150 hours).
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
11-12-2012, 07:35 AM
Enough tools to get the plugs out and the wheels off.
Sounds as though you already have the bag but I like those cheap camera bags you get on eBay. They are the right size and are usually padded. This keeps the baggage area happy.
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
11-12-2012, 07:43 AM
So if I'm packing a spare tube, I should also pack the Avery jack and a bottle jack. Man, that's a lot of weight.
11-12-2012, 07:46 AM
Duct tape can cover a number of things. In a pinch it can serve as a fuel cap and even patch a tube :-)
I agree with Tony and include a small solution for removing a plug and carry a spare plug.
I agree with Vlad and include a coil of safety wire.
I agree with Paul on the 'electronic gadget' ... I often fly with more than one
I have a baggy with a few screws, a few small tie-wraps, and a spare cowl fastener.
11-12-2012, 08:09 AM
A fresh credit card.
Actual repeat offender.
11-12-2012, 08:55 AM
Define the likely failures and what is needed to repair that may not be at an FBO.
Example: Nose tire flat. Tube. Allen wrench.
I carry a lot but am solo.
You should consider putting tools, etc in a small container that is secured on the front floorboard in front of the spar.
Carry less luggage if need be.
It is a trade-off.
