Old 07-15-2006, 07:31 PM
n468ac's Avatar
n468ac n468ac is offline
Lightbulb Has anyone tried adding vortex generators to the cowl exit air?
The hope is to help the exit air get out of the lower cowl and clean it up alittle, maybe lower CHT's?
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
Old 07-15-2006, 07:49 PM
Default H-m-m-m
Thinking is good but you never know for sure until you try. Do you want your CHTs lower? My recent experience is if everything else is unmodified and the CHTs come down - so will the speed. But that's not all bad. Then you can do something to cut down the air mass flow, increase the CHTs to an acceptable level and increase the speed. Tell me how it works out.
Bob Axsom
