Old 11-10-2012, 02:33 PM
Fedico94 Fedico94 is offline
Default oil sump plug Lycoming 1/2-18 NPT
When I replace this plug, is it tightened to a specific torque or just tight enough so it does not leak ? Had a hard time removing from a warm Aerosport IO-320.
Old 11-10-2012, 04:19 PM
Walt's Avatar
Walt Walt is offline
This plug has a compressable gasket, the torque is actually an angular measurement which I have found to be a little less than ideal. I use the "goodentite" method on this item (about the same torque as most pipe thread fittings ).
Oh no... not the dreaded pipe thead AN fitting torque debate again!
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
