  #251
Old 10-01-2014, 11:48 AM
SHIPCHIEF SHIPCHIEF is offline
Dan H chided me for wishing this power gain in a previous thread.
He suggested the inside of a Lycoming engine wouldn't support the kind of internal airflow required.
So I got out my trusty educational core engine case. The front 2 cylinders live in a closed crankcase chamber, with a 2" per side triangular hole under the main bearing. all the oil drain back to the sump, plus all the crankcase blow-by must pass thru this hole.
Bear in mind the front 2 cylinder's pistons go out and in together, opposite of the rear pair.
So the front & back crankcase chambers are pressurized and de-pressurized opposite of each other during each crank rotation.
Flow must fluctuate thru that little hole, with a constant average flow going aft with the oil drain back to the pan + the blow by flow thru the rear chamber toward the crankcase vent.
My point is that you can't get fluctuation free 'Low Crankcase Pressure' like an auto engine with a common crankcase.
Crankcase compression is going to happen with this old fashioned design engine, the higher the RPM, the less effective pressure averaging can occur between chambers.
I believe Dan's conclusion, and now mine, is: Large power gains from V8 auto engine tests won't be attained.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 10-01-2014, 01:39 PM
PerfTech's Avatar
PerfTech PerfTech is offline
Default Many or all race-teams disagree
... It isn't a question of airflow! It is a reduction of pressure and rareification of the trapped air in the crankcase.Ie;
http://www.dragzine.com/tech-stories...up-horsepower/
http://www.butlerperformance.com/ima...mpKit/evac.pdf
http://nutterracingengines.com/racin...uum_facts.html
http://www.gzmotorsports.com/vacuum-pump-guide.html
http://www.dragstuff.com/techarticles/vacuum-pumps.html
http://www.carcraft.com/techarticles...uum_pump_test/
http://www.429-460.com/t13910-moroso...g-check-it-out
...A simple search rendered this; About 443,000 results
I find it hilarious and difficult to believe that the finest minds, associated with the biggest, most well equipped, best financed race-teams in all types of racing, are misinformed and a couple of people on this forum know all the answers. I have seen the results in our dyno-cells myself so I know for a fact this works. Thanks, Allan...
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
Old 10-01-2014, 03:40 PM
BillL BillL is online now
I searched for "Stop Sign" and got 30,400,000 results.
Alan, share the data, maybe HP vs crankcase depression (vacuum) at a stabilized continuous power delivery condition. This would be like what we use at cruise or racing, and useful.
There is nothing wrong with saying it only gives us a clean engine and underside. That is valuable enough. Be Happy.
Anyway, the "piston pressure" is just bunk. The lower windage (flailing crank throws and connecting rods) with low density crankcase is very real. It should be known that this is but one of many sources of friction, and not very significant. Kinda like aerodynamic covers for fuel vents. Real, and small - - real small. I like them, they look cool.
Bill
RV-7
Lord Kelvin:
Old 10-01-2014, 04:27 PM
PerfTech's Avatar
.... The links I posted were so anyone interested could research for themselves. It somehow seems a fruitless effort for me to post some of these things as they always fall under much scrutiny, as if I were trying to mislead or misrepresent for personal gain. I guess this is just the nature of this type of venue. The list of documented results, and the corresponding reasons for the gains are all available and are virtually endless. Some of the important ones as applied to our application are laid out and discussed extensively on these links I posted. Windage, reducing piston ring flutter, better piston ring sealing from increasing top to bottom differential pressures, Stopping oil consumption via end gaps on rings, stopping oil coking in exhaust guides due to migration with no valve seals, cutting oil contamination of fuel via intake valve guides, boiling off moisture in oil at a lower temperature, dramatically reducing oil vapors and stopping them from being lost overboard and deposited on the bottom of your aircraft, just to mention a few. These things are far from "bunk" and are well documented if one takes the time to look. Thanks, Allan
Allan Nimmo
AntiSplatAero.com
RV-9A / Edge-540
(909) 824-1020
Old 10-01-2014, 05:47 PM
DanH's Avatar
DanH DanH is online now
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-01-2014, 06:03 PM
More than 2 months and 359 posts to yield this:
http://www.vansairforce.com/communit...&postcount=353
This issue is more complex. It will take years of therapy to resolve. Years.
Bill
RV-7
Lord Kelvin:
Old 10-03-2014, 02:48 PM
Josef's Avatar
Josef Josef is offline
Default Installed 2....
RV-8A / have installed the AntisplatAero oil separator + 2 x the saddle mount type pipe on my IO-360 ( installed it on different exhaust pipes ). Don't feel comfortable to have just one installed, just in case something does not go as planned...have flown 10 hours now with this setup, belly is of course oil free. Whether there is any reduction in oil consumption or some increase in power is too early to say. Checked the tubes for build up after 10 hours, so far there is none. Whether there is an increase of power I should see finally at the fuel consumption. Am recording it since first flight, keeping the same power settings over time there should be a reduction in fuel consumption visible. Will see...
https://picasaweb.google.com/1021719...77193941862306
https://picasaweb.google.com/1021719...77212434889218
https://picasaweb.google.com/1021719...77226876881010
https://picasaweb.google.com/1021719...77246507971442
https://picasaweb.google.com/1021719...77264478453922
https://picasaweb.google.com/1021719...77285717920530
RV-8A / YIO-360-M1B / 2 x P114 from Emagair
Old 10-06-2014, 12:27 PM
jcbarnes1 jcbarnes1 is offline
Default Replace Saddle Mount tube
Hi Allan,
Please also send me a replacement saddle mount with the inner-tube as well.
Jeff Barnes
9820 52nd St
Kenosha WI 53144
847-331-2567
Jeff Barnes, Race 411 RV-Gold
Old 10-14-2014, 06:56 PM
Tracer 10 Tracer 10 is offline
Thumbs up ASA Air/Oil Separator with new Saddle Mount
Between the two of us pilots we have over 100 years of aviation maintenance experience. One of us is an A&P the other an IA.
After exploring this thread from the first post to the last and reading ALL the information that Allan at ASA provided on this thread; we installed the ASA Air/Oil Separator and Saddle Mount with Air valve on our RV6, 160 HP Lycoming & constant speed prop.
This engine had had a history of creating "the greasy belly syndrome"...!!!
It would use about a quart of oil every 8 hours of flight; usually running it at 6 quarts for local flights and 7 quarts on cross country.
We have installed the ASA Air/Oil Separator and ASA's new Saddle Mount Air valve. The Air valve is mounted on the Right Exhaust Stack 12" from the tip outlet.
We also installed a second check valve (NAPA P/N: 2-29000) in the hose between the Separator and the Saddle Mount Valve; to preclude any issues with the exhaust saddle mount orifice getting plugged up with carbon..
We have added into our maintenance checklist; to remove the saddle mount at every oil/filter change to inspect/clean any carbon accumulation and test the check valves for proper operation.
The bottom line is that after 10 flight hours, two of which were 3 hours in duration and 10,000 AGL. THE OIL CONSUMPTION IS ALMOST ZERO AND THE BELLY IS CLEAN.
I can send pictures of the installation to anyone who wants them.
Old 10-14-2014, 09:14 PM
rvmills's Avatar
rvmills rvmills is offline
"But Joe (or Dan or Bill or Scott or Allan ), I want it all to be true?clean belly and more power?I tell ya...is that too much to ask?"
So this "Bill Gannon" rearranged the plumbing, and now the relief (backup) valve comes off the side of the tee, as Dan suggested (good call). Continued investigation of the oil drips located a seep from within the oil cooler. New oil cooler aboard, test flight good, and off to the Watsonville Airshow. 7 flights (6.6 hrs) later, and peering up in the cowl exit shows no oil, with a cleaner belly than after recent hops (some smoke oil residue, of course). Had the oil up to 9, and did use some, which has been true above 7-8 (of 12). Will see how this continues before the next oil change, and will see how the CVV tube looks at that time.
HP claims are enticing, and the idea of less belly shmear, with a tad of HP is something I didn't want to leave on the table?just in case?ya know, with those Wascally Wockets to chase around!
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
