09-30-2014, 08:19 AM
Originally Posted by dpansier
Bob,
I noticed in one of your photos you have 300 ohm twin lead running down the engine mount, what's the purpose and how does it perform?
Regards
Don,
That is a Howell Enterprises j-pole antenna for my APRS. It runs from there down the gear leg. I also have a bent-whip in my right wingtip for Comm 2, and have an MFG antenna switch under the panel which can switch Comm 2 and APRS between those antennae. The j-pole works surprisingly well there for APRS, even with the big titanium pole right there. The comm radio is fairly directional, and has some blank spots when using the j-pole in that location. Each does a little better when using the wingtip antenna. Always looking for ways to improve the hidden antenna program, if you have any thoughts!
Cheer,
Bob
09-30-2014, 10:18 AM
Originally Posted by Walt
Sorry can't help myself but I have to ask: can someone please remind me what the ACTUAL benefit is to adding all this "stuff" to your engine that has the potential of causing some very serious problems  Please don't tell me to keep the belly clean.
OK.
The logical reason is a reduction in case air density, and the consequent reduction of parasitic pumping losses. For example, my IO390 pumps 390 cu inches of air through the center main bearing case web with every revolution (195 from the front to the rear case volume, then 195 back again). A 10% reduction in air density requires less power to pump, and supports less aerosol oil.
Same reason your airplane has less drag at altitude.
Dan Horton
RV-8 SS
Barrett IO-390
09-30-2014, 10:42 AM
Originally Posted by DanH
OK.
Great theory but has anyone proven that it actually increases power in an aircraft application?
The real question is, is the risk vs benefit worth it?
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
09-30-2014, 11:33 AM
Bob,
Regards
Yeah! - - - I noticed that too, won't that big yagi be kinda draggy? I was thinking, that is REALLY old school.
Edit: Hey Bob I saw your answer after my post!. Interesting application.
Bill
RV-7
Lord Kelvin:
Reason: added comment
09-30-2014, 11:36 AM
OK.
You are killn' me here
Bill
RV-7
Lord Kelvin:
09-30-2014, 01:01 PM
Great question!
Mr. Nimmo has twice claimed HP improvement...
http://www.vansairforce.com/communit...9&postcount=17
...here 5 to 8 HP...
http://www.vansairforce.com/communit...5&postcount=35
...and we all want to see the dyno record. How about it Allan?
Heck, even Vic thought he saw a seat-of-the-pants gain:
http://www.vansairforce.com/communit...3&postcount=46
(Sorry buddy, the devil made me do it  )
There are experiments ongoing right now.
For some, clearly not. Others would like to pursue the matter, if it can be done with minimal risk, thus the safety valve.
How so?
Dan Horton
RV-8 SS
Barrett IO-390
09-30-2014, 04:49 PM
My buddy who is also a member here (McFly) added the unit to his plane and says that he got about 150 RPM more static or maybe it was take off, I don't remember, but I know he was conscious of accurately recording the before and after results. He did, however, say that he didn't notice any speed increase on the top end. I have installed the unit, as well, well actually two units - one on each pipe, but have nothing to compare it to as I installed it on a new motor. Before installing them we played with the angle and depth of the tap into the pipe using a water manometer and a shop back blowing through the exhaust pipe. I can't remember for sure but I think the most we could get at any particular angle And/or depth was about 1.5 inches of water which isn't much but then again I'm guessing a 360 exhaust may flow more than a 5hp shop vac.
09-30-2014, 08:02 PM
I highly recommend Anti Splat Aero's Air/Oil Seperator.
Currently installed on our RV6 with Lycoming 160 HP O-320 with constant speed prop.
Also the check valve that goes into one of the exhaust stacks.
Your oil consumption will go to almost zero and you will achieve extra horse power.
Also they have a unit for larger aircraft engines.
Check out their website videos.
AntiSplatAero.com
10-01-2014, 10:31 AM
i play with big block fords on four wheels, and a common addition to these is a vacuum pump on the case, the idea being that the pistons do not have to push against anything on the power stroke
you gain about 5-10% horsepower with these (electric vacuum pumps)
maybe that's what you guys are experiencing with this?
10-01-2014, 10:48 AM
I'm with you in theory. But what rpm are these auto engines turning?? Not certain of the exact relationship, but guessing the drag would be related exponentially to the rpm.
