Old 11-09-2012, 08:40 AM
Default new engine pickled for 8 years
I have read about 50 posts on pickled engines and what to look for. I am looking at a 0-320 that is new, in the box, filled with oil. It has been sitting in dry climate, heated hanger, for about 8 years.
What are the risks in an engine sitting that long? I don't think corrosion would be a problem since it is filled with oil, but I don't know what else to consider? Any thoughts would be appreciated. Thanks
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 11-09-2012, 09:17 AM
664781 664781 is offline
Default Pickled engine
Look at all the rubber seals. They may have dried out too much and start leaking. I bought a used engine stored like yours and changed out all the seals and gaskets prior to flying. No problems in 300 plus hours.
Your milage may vary!
Kurt Lohmueller A&P, DAR
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
Old 11-09-2012, 09:27 AM
mtnflyer mtnflyer is offline
Default Engine
Many years ago, when I was working on my 4, I found an 0-360 with 1500 hrs,first run out, mounted it and flew that engine for over 700 hrs before sending it out for overhaul. The hi dry air here in Colorado keep stuff like this in good shape,,, if the weather hold we will see you tonight at APA Dave
Old 11-09-2012, 10:45 AM
ppilotmike's Avatar
Default Sweet or Sour?
Rock,
Depends on how much vinegar/sugar was used. See you tonight at the Perfect Landing!
Mike
Mike Rettig
VAF Dues Current
Old 11-09-2012, 12:32 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
This. Just replace all the seals and gaskets while they're easy to get to... and you should be in great shape. Especially if the exhaust ports were plugged up during storage, if not, then you might want to inspect the exhaust valves with a borescope to see if there's any rust on the face of any exhaust valve & seat that was in the open position during the storage.
Neal Howard
Airplaneless once again...
Old 11-09-2012, 03:29 PM
Default Thanks
Thanks for the info. I think it is a pretty low risk although I do not know the cost of changing the seals and gaskets. That may be something I could do or have done for not too bad of a price.
I REALLY wanted a 0-360, but I am always open to a good deal!
rockwoodrv9a
Williamston MI
O-320 D2A
Old 11-09-2012, 04:15 PM
N941WR's Avatar
N941WR N941WR is offline
Default Not to worry
My first engine was pickled in 1959 and put in storage. When I got it home I pulled the jugs, inspected the inside, found nothing, put new rubber on it and flew it for 250 hours before I ran it into a trailer.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-09-2012, 05:05 PM
That is good news Bob. Well, except for the trailer part.
rockwoodrv9a
Williamston MI
O-320 D2A
