Old 11-08-2012, 07:30 PM
bhester's Avatar
bhester bhester is offline
Red face Lightspeed ignition - sensor wire routing?
I'm in the process of installing the new mini sensor, which has a sensor wire like the direct crank sensor. I need to see how others have routed their sensor wire from the front of the engine to the firewall, while avoiding spark plug wires and the coils. I have my coils mounted on top of the engine near the back. Thanks!
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 11-08-2012, 09:18 PM
Lars Lars is offline
Bobby-
I have a pile of photos if you are interested. Here's a small sample. Note that this is a dual Lightspeed installation. The blue tube is reinforced urethane, fairly high-temp rated (though I don't recall the exact value), slit and installed over the OEM cable to protect from abrasion/dirt/cuts/etc:
The last photo makes it look like the plug wires are resting on the signal cables. They aren't; there is at least 1" of clearance.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 11-09-2012, 07:03 AM
YellowPeril's Avatar
YellowPeril YellowPeril is offline
Routed mine underneath the cylinders on the side opposite the alternator. No issues in ~1000 hours.
Nick "Hairball" Knobil
RV8 N80549 (First Flight 2003)
Aerosport O-360A1A, Dual LS CDIs, WW200C
Bowdoinham, Maine
Old 11-09-2012, 07:17 AM
Same here, I went down between in the intakes on the pilot's side. Put an Adel clamp on the baffling to keep the wire away from any moving parts, then put Adels on the intakes (I want to say it was a DG-26), onto the engine mount and through the firewall in a passthrough separate from the output cables.
There was no interference with the two lower plug wires (#2, and #4) as both were routed from the mag (I have one mag and one LS) around the outside of the baffling. I have the LS box mounted on the left forward rib of the subpanel.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 11-09-2012, 08:39 AM
Rupester Rupester is offline
My crank sensor wire runs straight back under cyl 2 & 4 bundled with with the starter cable, then up thru the firewall near the top to the LS box on the left fwd subpanel rib (same as Bob's location).
The RG400 coil feeds emerge from the f'wall adjacent (not the same opening, just near it) run straight thru the rear engine baffle on the L side.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
