Old 11-07-2012, 06:26 PM
Kevin Horton's Avatar
Default Vans CB8-31 =Lycoming 65614 Plug, Baffle Attaching?
I need to acquire one of the round threaded plugs that go in each cylinder head, so an AN3 bolt can be used to secure the baffles. It is Lycoming part 65614, available for around $25, plus shipping from many places (Lycoming's list price is $24.57).
I'm wondering if Van sells a cheaper, non-Lycoming version of this part. My baffle plans are at the hangar, so I can't see if Van lists a part number for this part. Looking at "The List", I see a "CB8-31 ENGINE PLUG INSERT $8.00" in the baffle parts list. Is this the part I need?
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 11-07-2012, 06:53 PM
aerhed aerhed is offline
Are these the barrel nut things on 235&290's? If so, I've made them from a small piece of square stock and tapped to suit. Gets it done.
Actual repeat offender.
Old 11-08-2012, 03:02 AM
These things are barrel nuts, about 5/16" diameter. I'll make a temporary substitute by drilling and threading the shank of a bolt for now, but want to eventually put in something less likely to corrode.
Kevin Horton
RV-8
Moses Lake, WA, USA
Old 11-08-2012, 04:57 AM
g zero g zero is offline
The factory ones are just mild steel rod , The last set I got were bare , not even cad plate .
Old 11-08-2012, 11:49 AM
scsmith scsmith is offline
Default Darn, I just bought one for $25
No one has actually answered Kevin about the Vans part, but it would have been nice to know two weeks ago. I bought one from Lycon.
Well, anyway, I made some measurements and put a drawing in my engine log book, so next time, I can make my own. Geez, $25 for a half-inch long piece of 5/16 rod with a tapped hole in it - that is off the charts even for airplane parts.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 06-08-2014, 11:38 PM
ppakotze ppakotze is offline
Default How to fix the insert
Is there a trick to make these inserts stay put while working on them?
Some loctite or high temp RTV just to hold them while you fit the baffles and bolts?
Once the AN3 bolt is in that will obviously keep it there, but otherwise you run out of hands?
Regards
Pieter
