Old 11-07-2012, 12:04 AM
Berchmans Berchmans is offline
Default Tip: Wing Tip Lighting
Here is how I installed my wing tip lighting. I used the AEROLED 800 series landing light and fabricated a small bracket out of a piece of scrap angle. The landing light is held in place with 6 series screws and plate nuts and the nav lights are mounted using 4-40 screws and plate nuts. This all fits neatly under the supplied wing tip lense.
[/IMG]
Burke Wick
Flying RV 8
Anchorage, Alaska
VAF Dues Paid for 2020
Old 11-07-2012, 12:14 AM
az_gila's Avatar
az_gila az_gila is offline
Question
Doesn't that shade the nav light in the rear portion of the required 120 degree coverage field?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-07-2012, 01:03 AM
Default Nav shading
The angle of the photo is a bit deceptive...the Nav is not blocked the landing light and when activated it is blinding bright. Angle between the last row of LED's in the light and the edge of the landing light is parallel to the plane the landing light is mounted on...
Burke Wick
Flying RV 8
Anchorage, Alaska
Old 11-07-2012, 06:39 AM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
Default Cooling
I wonder if there is sufficient air movement under the lens to cool the landing light? I plan on mounting mine with the back heat sink through the fiberglass to access the volume of air within the wing...
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Sept 8, 2019
Old 11-07-2012, 05:23 PM
Default Cooling
Generally the lights will be in the wig/wag setting and don't seem to generate much heat that way...time will tell...
Burke Wick
Flying RV 8
Anchorage, Alaska
