For the future reference, here's the reply from Klaus:
"It does not matter if the second sensor is at 120 or 240 degrees, the phasing procedure will assure that the sparks go to the right cylinders."
So the picture above will work fine. Also, if it's mounted at the 'other 120 degrees' it'll work as well.
Best,
-Jim
