Ok I can't find it on here so I'm asking...
I have an ACS switch and dual P-Mags. ACS says to shield EVERYTHING. Bob Nuckolls says nothing I can find about shielded wire. Here is the Z-13.
http://www.aeroelectric.com/PPS/Adob...dfs/Z13-8R.pdf
(Now remember this is not "Mags" on Z-11. It's Z-13 with P-Mags)
Also I did not see anything in the instructions from Brad at E-Mag about using shielded wire. He just said use 18ga for power and ground and 20ga for the rest.
So ACS switch, to shield or not to shield?
Thanks in advance.
