Wicks doesn't list the MS21053-L08 nutplates online. However, I've found that they will often special order items for you. When I built my fuel tanks, my local RV guru told me that none of the certified aircraft companies would ever use standard MS21047-L08 (K1000-8 for you folks who use obsolete part numbers) nut plates.
He explained that it was the use of these nut plates, not the cork gaskets which cause all the grief with sealing the fuel tank access plates. REAL airplanes use special NAS 1473 self sealing nutplates in fuel tanks. He was right, my fuel tanks never leak. I called everyone, but no one I asked had them. You need 24 per aircraft. The lady at Wicks told me she could special order them for me, at $4 each. However, if I ordered 100, the price would drop to $2 each. I arranged a group purchase with the other local RV builders and ordered these from Wicks. I've mentioned these items on the various RV lists over the years. The outcome is that Wicks now stocks these items. See
http://www.wicksaircraft.com/catalog...381/index.html
I would also check B&B Aircraft Supply (no web site) call them at 913-884-5930 This is the company that has the awesome variety of hardware at Sun N' Fun every year.
Another company which is a bit more expensive is M&M AeroSpace Hardware. These folks have EVERYTHING when it comes to aircraft hardware. They are setup to deal with aviation companies, but will sell to individuals. They've got stuff you most likely have never heard of, like stainless steel nutplates (use near a compass, near a firewall or in highly corrosive environments) They have 5 locations across the US. See
http://www.mmaero.com/us/index.cfm
FYI, you have to set up an account to purchase from them. Their Miami location takes up an entire city block. If they don't have it, it doesn't exist. You can download an Excel spreadsheet file which lists everything in their monthly inventory. They also discount heavily when purchasing in lots of 100.
Charlie Kuss
