Old 11-03-2012, 04:23 PM
dbuds2's Avatar
dbuds2 dbuds2 is offline
Default First Flight Fuel Pressure
ECI-IO360 supposed to be 14.5 psi, here's what I had today on first flight: OK? Is 40 psi OK?
Bud Smith, RV-8, ECI IOX360 , Dual PMags, Dynon SkyView, Whirlwind 200GA, IFR and N88ZP has "slipped the surly bonds of earth".
Old 11-03-2012, 04:36 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Is that with just the engine driven pump or with the boost pump on? For my IO360-B1B, I believe the spec is 33PSI at the fuel pump inlet; the boost pump drives slightly higher than this.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 11-03-2012, 04:47 PM
Walt's Avatar
Walt Walt is offline
14 PSI sounds about right for the ECI AE fuel injection system. You'd be flooding it terribly with 40 psi, probably would not even run at low power if the pressure was really that high.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 11-03-2012, 05:16 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Congrats!!
Congratulations on the first flight
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-03-2012, 05:30 PM
cfiidon's Avatar
cfiidon cfiidon is offline
Default AE Data Sheet
Bud,
I just went though the fuel setup with my ECi XIO-360 with Automotive Engineering (AE) fuel pump.
At idle, the unmetered fuel pressure should be 6-8 psi. At full power, 2700 rpm, the unmetered fuel pressure should be 24.5, the metered fuel pressure 20 psi, and the fuel flow 16.2 -17. EGTs are also specified.
If you are seeing 40 psi unmetered, then your metered fuel pressure is probably over 30.
I'd recommend finding a 0-30 fuel pressure gauge and go thru the setup again. When I did, I adjusted the high pressure relief to give me 20 metered pressure, and that made the unmetered fuel pressure more than 30 psi. I dialed it down a bit and was satisfied with the best I could get as a compromise, that being 27 unmetered, 18-19 metered, and a fuel flow 16.2+.
Here's a link to the data sheet with those set-up values, and the AE pump documents have the procedure.
CONGRATS on the first flight!!!
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 11-03-2012, 05:47 PM
Rhino889's Avatar
Rhino889 Rhino889 is offline
Buds ground/video team is working on editing.
Video to be posted soon.
Excellent 1st Flight!
VAF DUES 7/13, 12/13, 03/14
Founder/Director
www.Aircraftwraps.com
This is my personal account and does not reflect the official communications of Aircraftwraps.com. We have retained a username for such correspondence. I post about formation, eating, aerobatics and pilot stuff .
Old 11-03-2012, 05:57 PM
6 Gun 6 Gun is offline
Default fuel
Did you run a return to fuel tank?
Old 11-04-2012, 03:06 AM
dbuds2's Avatar
Default More Information
Thanks for your prompt replies and keep them coming..
Yes, return lines from the pump/separator back to duplex Andair valve to each tank.
The electric boost pump was off, the engine ran smooth the whole flight, not to rich.
I'm pretty sure I noticed the pressure rise when I switched from the left tank to the right tank. I continued flying for a while longer, and when I checked the pressure back on the left tank, it was still high.
Possible causes: Bad gauge tranducer, blockage in the return circuit, bad pump, Skyview electrical. I have a call into ECI to discuss with their experts.
Old 11-04-2012, 09:51 AM
Mike S's Avatar
Senior Curmudgeon
Make sure you have the correct sender also.
Fuel and oil pressure senders look the same, but will not give accurate readings due to different internals-----------been there, done that.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 11-04-2012, 11:10 AM
sailvi767 sailvi767 is offline
I have your setup with the ECI injection. I suspect that you have a bad indication. My engine will not run smoothly with that kind of fuel pressure. The ECI system is not designed to run with a high pressure fuel pump running with the engine pump at the same time. The pump is a backup in case of a failure of the engine pump. If I turn on the pump with the engine running it gets rough instantly from the higher pressure and the very rich mixture that results. The ECI system is different from most other injections systems and functions most like the continental system.
George Psaros
RV6 ECI IO360
