Old 11-19-2012, 06:32 AM
Originally Posted by n761tj View Post
Avblend is a single component, thin mineral oil. It was created in the 1950's.
Some people swear it helps with valve sticking. If it works for you great!
I have tested it thoroughly for wear and corrosion protection and it only hurts performance because it thins the oil reducing the oil film thickness. The thinner oil is what gives them the claim of better fuel economy. It evaporates in about 5 hours in most aircraft.
Camguard is comprised of 11 high performance additives and is 100% active with no diluents. We offer demonstrable proof of performance in rust and corrosion protection, deposit control (the only product to do so), wear reduction and seal conditioning/protection.
Avblend sponsors Sean Tucker, which is fine.
It took Mike Busch 2 years to test Camguard for himself. He is not on our payroll.
You should look at both companies data and judge for yourself.
Ed
Thank you, I will.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 11-19-2012, 08:17 AM
n761tj n761tj is offline
Originally Posted by rocketbob View Post
Yep. I have a friend that mixes Phillips Tropartic with X/C and is working with an engineer from Phillips who regularly samples his oil. Troparctic is high in ZDDP, is that what you are concerned with? As I understand it the newer diesel oils are made to work with particulate filters and have to be low in ZDDP to avoid getting ash deposits in them.
The Tropartic has slightly reduced ZDDP but the highest metallic content is from the overbased detergents and is thus the biggest problem. It is interesting that a Phillips engineer would would gamble with his friends life by promoting the use of an ash containing oil in an air-cooled aircraft engine. The oil may test just fine even after the engine fails due to catastrophic preignition caused by metallic ash deposits in the combustion chamber.
Ed
Old 11-19-2012, 08:25 AM
Originally Posted by 6 Gun View Post
Bought a 182 from up north that used Exxon 15-50 and two cans of avblend every 25hrs oil change had cyl in 400hrs so I started to wonder what went wrong in my thinking heres what happened . Cold engine 15w oil when cold add two cans of avblend maybe 5w maybe 10w on take offf when you need the best protection dont get it till engine gets hot.looked at msds sheet and seen that avblend was 99% mineral spirits and hydrofluoric acid .You might want to see whats in Cam guard before you run it. they have some nice T shirts though.
Bob
Avblend is 99% thin mineral oil (0W) not mineral spirits a solvent (charcoal lighter fluid) and 1% ether (starting fluid). Where did you get the hydrofluoric acid, one of the most dangerous compounds around?
Ed
Old 11-19-2012, 10:07 AM
N427EF N427EF is offline
Default Thanks Ed
Ed, thank you for posting here and sharing your expertise.
I dislike air/oil on aircraft because of the chemical activity of the blow-by gasses and aircraft engines produce a lot of blow-by. ANY blow-by returned to the sump is bad.
I was just considering an air/oil separator installation, maybe not such a good idea. I have heard the same story before but coming from you, it carries more weight.
I may be dropping Avblend in favor of Camguard now.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 11-19-2012, 10:30 AM
Ernst,
I suspect your concern is a dirty bottom skin from the breather. I went the separator route with a previous airplane and it never worked well, seemed like the blow by took a lot of stuff with it not withstanding the separator feature. Also, the separator can needs regular service as it does capture water and other junk coming out to the engine. I can not imagine plumbing it back into the crank case.
What seems to work reasonably well with regard to keeping the bottom skin kind of clean is routing the breather exit just above one of the exhaust stacks. The hot pipe probably super vaporizes the breather stuff and there is less mess on the bottom skin.
RV-12 Build Helper
RV-7A...Sold #70374
Old 11-19-2012, 10:50 AM
DanH's Avatar
DanH DanH is offline
Thank you Ed. Serious question; would you judge CamGuard to be an adequate prophylactic against that chemical activity?
Dan Horton
RV-8 SS
Barrett IO-390
Old 11-19-2012, 11:19 AM
rocketbob's Avatar
Ed
He's been flying his rocket for a number of years with a 50/50 mix of Troparctic and X/C, and probably averages 120 hours/year. When the formulation changed for Troparctic they (Phillips) had him dial the ratio back a bit. I will ask him tonight but he has had absolutely no problems with the oil mix itself. I've seen the inside of his 540 and its clean as a whistle, but he has had a few cases of sticking valves. I know several other people that have run full synthetics with few problems.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 11-19-2012, 11:34 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Ed
And if the captured fluid is not returned to the crankcase????
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-19-2012, 12:04 PM
This is ong thing that Camguard does very well. It quashes the chemical activity of the reactive species found in the blow-by.
Ed
Old 11-19-2012, 12:19 PM
Why have you seen the insides of his engine?
If the engine was so clean why did he have valve sticking? Ash deposits in the guides?
Did it look as clean as our certification engine? Note valve guide
http://aslcamguard.com/wp/wp-content...ion-Engine.pdf
Have you looked for combustion chamber deposits? The main issue.
I find it improbable that this was a Phillips (company) sanctioned endeavor.
Ed
