11-11-2012, 07:48 PM
Originally Posted by aerhed
Don't forget the cooler flush and governor if you've got one.
Great advice - send the oil cooler to Pacific. It must be FULL of metal and they have a special system to get it out of there.
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
11-12-2012, 10:56 AM
metal
been through this a bunch. You have a cam and/or lifter problem. cheaper to tear it down now than wait, have the cam and lifters reground or replaced before you have to do the entire engine.
Regards,
Gary
11-12-2012, 07:45 PM
And the prop if C/S.........................
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
11-12-2012, 08:00 PM
Don't let these SIMPLE engines scare you. Get the manuals. Anyone with even a half a brain can rebuild one... on and off the aircraft in a few days if they are prepared.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
11-12-2012, 09:39 PM
That advice is not universally accepted. Mike Busch, of Savvy
Aircraft Maintenance fame, and a regular EAA webinar presenter advises that any time multiple cylinders are to be removed that the work be done by a respected engine shop. The reason for this is that you are removing multiple case through-bolts, and there is the potential for uneven tightening and misalignment upon their reinstallation that can cause serious problems. This advice from the guy who preaches to anyone that will listen on how to minimize maintenance.
Erich
11-12-2012, 09:48 PM
Erich
Yup... they make a BUTTT load of money preaching too. Get the Manuals and it is a no brainer... well some brains I guess. You need to know how to read.
Reiley
VAF# 671
Friend of the RV-1
11-13-2012, 08:31 AM
A monkey can stack a lycoming....when he's not screwing around flying.
Actual repeat offender.
Wow, not sure why you think this is true. The webinars Mike does are free on the EAA website, his articles are available in Sport Aviation and the Avweb archives, and he came and gave a 2 hr presentation at my EAA chapter at no charge afterwhich he answered all questions until folks couldnt think pf anymore. He also has a FREE service (for now) to evaluate engine monitor data. He hasn't made a cent from me yet has been an invaluable source of info. I don't think money is his motivation.
Erich
11-13-2012, 09:07 AM
I'd add that I think it's slightly beyond reading the overhaul manual - not too far, but not quite so simple.
My perspective is from having done an engine and having attended the Lycoming school. Opinions may vary, but mine is that you would do well with the school or similar "hands on" experience.
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
11-13-2012, 10:27 AM
There is no misalignment that can happen because the thru-bolt holes are drilled and reamed at the factory, and for them to wear to a point where there would be misalignment would be highly unlikely. Lycoming does not specify tolerances of fit in the OH manual but they do in a service instruction. On some Continentals I've worked on the fit of the thru-studs are sloppy and there are also no fit tolerances specified in the manual, but those engines have dowel pins on parting surfaces to set alignment. In other words, the fit of the thru studs can be sloppy and thats acceptable, but I don't put them together that way. I have reamed and gone oversize with a tight fit. I wouldn't rehash internet knowledge here unless you have the practical experience to back it up.
As far as tightening goes, there is also a SI on the order of how the bolts are torqued. I know how to read and operate a torque wrench and don't work in a repair station so your logic is flawed there also.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
